Тема: KOSMIK - new line 14S ESC from Kontronik.  (Прочитано 88885 раз)
« Ответ #315 : 10 Февраль, 2016, 09:05:21 am »
Раптор Е700, Скорпион 4235, Космик 160, Вбар нео, 14S 4500 мАч, вес 4900 гр. Обороты 2100.
Оффлайн Helimika
    • Морозов
« Ответ #316 : 01 Март, 2016, 16:59:25 pm »
Hello. Please could you clarify something regarding my Kosmik 200 (not cool version).
I'm using this ESC in my Goblin 700 (not competition) and have no possibility to install additional radiator to the ESC (or use Cool version) because there is lack of space inside of helicopter frame.
I have found that temperature of ESC reached 67 degrees Celsius during flight when ambient temperature was only +4 C. So I'm worry that ESC easely can reach 90-100 C when ambient temperature will be 25-30C/
Will ECS be damaged in this case? Or it has some protection when reaches 100 degrees?
Probably you can provide some suggestions regarding uising this ESC in Goblin 700?
I have attached LOG file during flight I mentioned above.
Thanks.
Dear Sir,
the controller have a protection with 90 to turn off in 60 sec.  and 100° cut off the Motor.
So is it very hot in summer is the different closer like at Winter to the 90 ° C
Mit freundlichen Gr??en aus Rottenburg  ||  With kind regards from Rottenburg
KONTRONIK Support-Team
Вобщем не должен Космик гореть при перегреве.
Оффлайн vadson
    • Vadim
    • Chareuka
« Ответ #317 : 01 Март, 2016, 17:15:35 pm »
Сегодня знакомый звонил микадовцам,  узнавал хватит ли 160 космика для 800ки.  Сказали что за глаза. Сказали что кул версии нужны только для африки с ихними 50гр.  А у Вас на 700ке такие температуры.
[01.03.16, 9:32:21]  I called my friend who is in Mikado team, and he comfirmed that 160 amps is more than enough
[01.03.16, 9:32:51]  some countries like Africa, where the temp is 40-50c using cool version, but its extra insurance not to go to fail saife
[01.03.16, 9:32:57]  except this 160 amps is enough
У меня на алайне 700дфц с мотором 800мх обороты 2100 стоит регуль 120про, после установки на него маленького радиатора из комплекта, не разу не испытывал проблем с перегревом. Хотя место установки не самое лучшее.  При этом токи у меня под 200 ампер фиксирует Вбар контрол, а он фиксирует пики равные 100мс., кратковременные иглы он сглаживает за промежуток времени в 100мс.
Что думаете господа?  Почему на гоблинах у народа стоят 200 космики и им там жарко?  Интересно на каких оборотах летает народ.
Летим на МАРС ?
Оффлайн Helimika
    • Морозов
« Ответ #318 : 01 Март, 2016, 17:38:45 pm »
Вот мое предыдущее сообщение - крик души в Контроник. У меня как раз 200й нагрелся до 67 градусов, когда на улице было +4 градуса. График могу приложить. Соответственно, летом будет 97 градусов.
Космики греются на 12 банках. Причем, когда начинаю летать на Генсах (1 и 2 полет) температура не поднималась выше 56 градусов, а на Турнигах (3 и 4 полет) уверенно ползет к 70ти. Поначалу мне показалось, что рег каждый раз прогревается больше потому, что теплый еще с прошлого полета, но в итоге, я понял, что на турнигах больше просадка по напряжению и выше токи.
Плюс температура стала выше когда поставил новый мотор просто ацкой мощности Хнову 4530-525. С ним верт начал отстреливать так, что шаськи чуть на земле не остаются. Обороты ровно 2200. Лопасти 710 мм RJX.
Радиатор в мой Гоблин не лезет никакой. Плюс в Гоблине место его установки не обеспечивает притока воздуха (мне кажется вобще). Так что у меня вариантов нет.
Я написал в Контроник и спроил могу ли я таким образом (перегревом) повредить, дорогой сердцу, девайс. Они ответили, что стоит временная отсечка на 90 градусов и моментальная на 100 градусах.
Чтобы выйти из положения, я установлю TelMe и установлю оповещение на 90 градусов. Буду летать ака на нитре  :)
« Последнее редактирование: 01 Март, 2016, 17:48:25 pm от Helimika »
Оффлайн Helimika
    • Морозов
« Ответ #319 : 01 Март, 2016, 17:43:52 pm »
А по поводу необходимости 200ки вопрос скорее риторический. Это как с сервами Футаба 272 и 275. Есть достаточное условие для полета, а есть понты.
Хотя мне удавалось достичь долговременных токов (более 30 секунд) выше 200 ампер при выполнении силовой воронки. Акки были Генсы 45С 5500, мотор Контроник 850 Компетишн, верт Компас 7HV. График тока выкладывал в ветке про 7HV.
« Ответ #320 : 01 Март, 2016, 17:44:33 pm »
С точки зрения физики все закономерно.
Оффлайн Helimika
    • Морозов
« Ответ #321 : 01 Март, 2016, 17:51:19 pm »
Да Ярослав. Данные о температуре твоего регулятора при использовании 14S это подтверждают.
Мне только интересно, если в 200м изначально больше ключей, чем в 160м, то при одинаковых токах 200й греется больше? Ведь кажный ключ при переключении генерит тепло.
« Ответ #322 : 01 Март, 2016, 18:01:41 pm »
Нет не верно, каждый ключ при открытии и протекании через него тока рассеивает на себе тепло. Чем больше ток тем больше рассеивание тепла. Так что все наоборот.
« Ответ #323 : 01 Март, 2016, 19:05:12 pm »
У Космика очень неудачно выполнен теплоотвод от платы БЕКа ,точнее его там нет вообще.Бек стоит посередине ,в пластиковой обечайке ,и прилично греется при работе .По расчетам максимальный КПД бек должен иметь при работе от 50 вольт с дросселем 10мкГн ,а стоит 5.6 мкГн ,с такой индуктивностью ему не выйти за 87 % при токе более 3 ампер,больше ток -ниже КПД,вплоть до 80% ,при 10 мкГн -95% .А темодатчики у Космика стоят и на плате Бека и на плате регулятора ,так что понятно что быстрее нагреется  :D.
 А бек между прочим питает в Космике абсолютно ВСЁ!! И если бек вырубится от перегрева -вырубится все и сразу,причем микросхема Бек имеет и внутреннюю теплозащиту ,независимую от процессора ,и если будет локальный нагрев более 100 градусов,она и сама все "погасит"  :)
Оффлайн Helimen
    • Коноплёв
« Ответ #324 : 01 Март, 2016, 19:08:12 pm »
Тема "голды" требует, бес сомнения , полного раскрытия!
Придётся тюнить и прокачивать весь вертолёт, иначе цимус в песок уйдёт.
1. Регуль должен быть хорошо виден : или капот прозрачный, или вообще без капота.
2. Разъёмы и крепёж на регуле - тоже однозначно золотые, причём без всякой пошлой
термоусадки, всё должно быть открыто и блестеть.
Тут полумеры недопустимы!  :D
  А лучше вообще от разъёмов отказаться. А то вдруг возникнет перекос фаз. А потом тут некоторые ломают головы "почему у них кастлы 160 горят, или хер пойми по какой причине в отсечку уходят?"  :-[
« Ответ #325 : 01 Март, 2016, 21:38:23 pm »
Такого "Колхоза", не видовал наш форум! ;D :D ;)
Оффлайн Helimen
    • Коноплёв
« Ответ #326 : 01 Март, 2016, 21:46:51 pm »
Слыхал басню Крылова про петуха и золотое семечко?  Это про тебя  :D
« Ответ #327 : 01 Март, 2016, 23:21:34 pm »
Ты зря все это сделал.
У меня моторный разъем как-то испарился во время полета. Ничего кастлу от этого не было.
Ты б лучше батарейки припаял. Хоть нас всех порадуешь :)
Оффлайн vadson
    • Vadim
    • Chareuka
« Ответ #328 : 01 Март, 2016, 23:31:04 pm »
ходят слухи, что хозяева гоблинов перетягивают свои ремни от силовой, и примерно 20-40 процентов энергии тратят из-за этого на передачу энергии.  Что скажете?
Летим на МАРС ?
« Ответ #329 : 01 Март, 2016, 23:35:29 pm »
Да припаяй сразу штангенциркуль, чо там.
Я до сих пор под впечатлением, от его сверления.
