Тема: Настройка Castle Creations Phoenix-80 Brushless ESC  (Прочитано 21880 раз)
Оффлайн McMaxicus
« Ответ #75 : 06 Август, 2009, 07:20:42 am »
Новые прошивки вышли для Фениксов!!!
2.161     Beta     08/05/09
    * CastleLink V3.16 would fail to properly update a specific version of the Phoenix HV controller line. If your controller was affected by this bug, please install CastleLink V3.161. Then, link your controller, go to the 'Software Tab', and click on 'Update Firmware'. You will not be alerted that there is a new version of firmware available, however after your controller's firmware is updated with CastleLink V3.161 it will function normally. Please contact technical support if you continue to have issues.
2.16    Beta    08/03/09
    * First public release of Phoenix ICE controllers
    * Added 'Outrunner Mode' PWM Rate to Phoenix 35 and higher controllers
    * Improved the performance of motor startup
    * Changed governor mode behavior - the governor will no longer lock at low throttle outputs
Оффлайн McMaxicus
« Ответ #76 : 13 Октябрь, 2009, 19:50:14 pm »
Новая прошивка 2.18, по прежнему Бета... :
    *  Auto-Rotate mode now works in 'Heli-Fixed' (not governor) mode
    * Auto-Rotate engage is now a quicker and more linear ramp
    * ICE Controllers could (incorrectly) quickly ramp to full throttle if in governor mode
    * Occasional motor 'tick' while running has been removed
    * Improved ability to run some outrunner-style motors, especially very high-inductance motors
Да, и новый Кастл линк...
