Тема: Lithium Balancer PB-6 Bantam  (Прочитано 2839 раз)
« : 30 Апрель, 2009, 21:14:18 pm »
http://www.helidirect.com/lithium-balancer-pb6-cells-p-2031.hdx
Хочу попробовать этот балансир, взамен сдохшего, знатоки, как характеристики?
 Perfect balancing the Lithium battery(Li-Po, Li-Io, Li-Fe) with maximum accuracy
It monitors the voltages of each cell during the charge process to equalize the peak voltage.
We guarantee the final voltages are nomalized with an accuracy less than 0.01V.
PB-6 can be used with any brands of charger but you had better use it being linked with e-STATION chargers
High circuit power that enables fast-balancing
PB-6 adopts bigger capacity of circuit to perform balancing rapidly. It can drain the current from each cell up to 500mA at a time. It is very essential for balancing the larger capacity of batteries.
- Capable of self-balancing without a charger
PB-6 can be self-operative without linking to charger. When you connect the battery pack to the individual port of PB-6 the balancing job will be started instantly. In this case the individual cell voltages will be equalized to the least cell voltage of the battery pack.
« Ответ #1 : 30 Апрель, 2009, 23:53:23 pm »
Всё вроде бы нормально, но добиват это: "We guarantee the final voltages are nomalized with an accuracy less than 0.01V."
То есть, в случае чего - ни кто не обещал НОРМАЛИЗАЦИИ напряжения, а всего лишь НОМАЛИЗАЦИЮ с точностью 0.01В  ;D
И "взятки - гладки"  :-[
Шутка!
Дак ктож его знает?  :-\ Только тот - кто пробовал!
« Ответ #2 : 24 Май, 2009, 08:31:41 am »
Купил в итоге вот эту штуку.
TWO-METER is a very sophisticated electronic device that controlled by high performance microprocessor and precise resistors. It has three functions of ‘watt-meter’, ‘battery checker’ and self-balancer. Those functions are essential for electric flyers to ensure safe battery condition and to measure the electric consumptions of the power system. And also, the built-in self-balancer can equalize the individual voltages instantly.
 TWO-METER can handle all types of Lithium batteries(LiPo, LiIo, LiFe) consisting of series-wired cells, but the battery pack has to have a balancing plug for checking voltages.
-  Watt-meter program
 The Watt-meter circuit can measure the electric current up to 100A. You can verify the electric consumptions on your power system.
TWO-METER can show you the voltage and residual capacity of your Lithium battery pack with its individual voltage of each cells.
- Integrated self-balancer
TWO-METER has an integrated self-balancing circuit which is self-operative without linking to charger. When you connect the battery pack to the individual port of the device the balancing job will be started instantly. In this case the individual cell voltages will be equalised to the lowest cell voltage of the battery pack.
Specification
Input Power max. 60V
Max. current (Watt-meter) 100A
Min. operating voltage 7.2V
Power consumption (Battery checker) approx. 20mA
Battery checker 2~6S LiXX
 Ватт метр мне не особо нужен, взял из-за дисплея, чтобы видеть, как балансируются банки.
Есть у него одна особенность, если его подключить в режиме балансира, как только банки все выравняются, он отрубается и дальнейший заряд идёт без его участия и если на старой батарейке начнётся разбаланс, балансир  приходится запускать заново.
 Но тем не менее сравнивал его со старым гиперионовским балансиром-этот банки быстрее в конце выравнивает, даже старые батарейки очень шустро равняет, пока вообщем нет чувства, что деньги потратил зря. Купил его взамен здохшего балансира в Гиперионе.
Еще показывает процент оставшего топлива в батарейке, напряжение соответственно в каждой банке.
Оффлайн rpilot
    • RC-COMBAT
« Ответ #3 : 24 Май, 2009, 11:24:51 am »
Предыдущий Бантам PB6 dual-link тоже хорошо работает у него из всех самостоятельных балансиров самый высокий ток балансировки - 500 mA.
« Ответ #4 : 24 Май, 2009, 12:09:23 pm »
 У нас есть предыдущий Бантам БС6 зарядник, вот у него встроенный балансир мне не очень понравился и плюс общее напряжение у зарядки и у нового балансира не совпадают, если подключить этот балансир к Гипериону, то там всё практически идеально, думаю все старые зарядки оснастить этим девайсом, очень понравилась скорость балансировки.
« Ответ #5 : 14 Июнь, 2009, 20:24:29 pm »
Пришли балансиры PB6, балансируют шустро, но без обратной связи с зарядкой, быстренько банки отбалансируют и отрубаются, и к окончанию заряда, банки слегка разбалансированы, без работы балансира, приходится перезапускать второй раз балансир :( не совсем удобно)
Оффлайн Racdyn
    • Бабкин
« Ответ #6 : 14 Июнь, 2009, 22:23:41 pm »
Роббевские 6 баночные балансиры рулят всеже.Хоть токи и меньше,но есть связь с зарядником
Оффлайн Fedy
    • Фёдор
« Ответ #7 : 15 Июнь, 2009, 01:59:30 am »
пользуюсь такой зарядкой\балансиром
Align Intelligent Balance Charger RCC-6CX
http://www.helidirect.com/align-intelligent-balance-charger-rcc6cx-p-7631.hdx
мне оч нравится   :круто:
« Ответ #8 : 15 Июнь, 2009, 06:50:43 am »
Лёх у них тоже связь есть, только зарядку нужно Бантам и более точно банки балансирует всё таки девайс с дисплейчиком, эти монстры будут хороши под большую ёмкость и быструю зарядку, испробуем на Гипнерионах G3
