Тема: Гироскоп Align RCE-600 Head Lock Gyro Combo DS520  (Прочитано 3695 раз)
« : 16 Июнь, 2008, 20:44:01 pm »
RCE-600:
?Utilizes AHTCS (Active Helicopter Tail Control System) to compensate any drift caused by wind direction and force, as well as unintended yaw induced by helicopter itself during flight maneuvers.
?Tailor made specifically for use with high speed digital rudder servos. This gyro festures high sensitivity and minimal reaction time, fully utilizing the potential of modern high speed digital rudder servos.
?Gyro locking mode and gain can be adjusted remotely from the transmitter.
?Digital/Analog servo switchable.
?Reverse switch.
?Delay adjustment.
?Rudder servo travel limit adjustment (ATV).
?Ruddersevevo neutral setup mode.
DS520:
?Coreless Motor Design for fast speed, high efficiency, and low power consumption.
?10 Bits signal resolution for smooth movements.
?Response time of 0.07s/60°. High strength composite alloy gears with high precision and durable structure characteristics.
?Aluminum alloy mid case construction for instantaneous heat dissipation, maintaining servo’s high efficiency.
?Supports digital & analog control signal.
?Powerful and precise servo suitable for T-Rex 500 CCPM cyclic and rudder servo use.
   RCE-600 Ratings:
?Operating Voltage:DC 4.5~6V?
?Current Consumption:<20mA @ 4.8V
?Angular Detection Speed:600 degrees/sec
?Operating Humidity:0?~65?
?RoHS certification.
?Operating Humidity:0%~95%
?Size:27.6x26x14.5mm
?Weight:9g
DS520 Ratings:
?Stall torque:1.9kg.cm(4.8V)
                    2.5kg.cm(6.0V)
?Motion speed:0.09sec/60°(4.8V)
                     0.07sec/60°(6.0V)
?Rating voltage:DC 4.8-6V
?Temperature range:-20°C~+60°C
?Dimension:35 x 15 x 29.2mm
?Weight:25.9g
Accessories:
?Double-sided tape x2 sheets
?Servo rudder piece x 3
?Set screw x 1
?Rubber damper x 4
?Brass grommet x 4
?Tapping screw for servo x 4
« Последнее редактирование: 04 Октябрь, 2008, 22:23:49 pm от SkyForever »
« Ответ #1 : 17 Июнь, 2008, 08:59:17 am »
Можно также заказать этот гироскоп с сервой HS-5084MG Hitec
Servo Ratings:(Digital Metal Gear Servo)
?Motion Speed:0.07sec/60°(4.8V)
                      0.05sec/60°(6.0V)
?Output torsion:1.5kg.cm(4.8V)
                       1.9kg.cm(6.0V)
?Size:29x13x30mm
?Weight:21.7g
« Последнее редактирование: 04 Октябрь, 2008, 22:24:12 pm от SkyForever »
« Ответ #2 : 17 Июнь, 2008, 09:03:36 am »
Редуктор на Алиговскую серву тоже доступен по гуманной цене в 6у.е.
« Последнее редактирование: 04 Октябрь, 2008, 22:24:38 pm от SkyForever »
« Ответ #3 : 08 Июль, 2008, 11:05:37 am »
Посмотрим, что у них получилось, один на тест уже заказали, говер то у них получился зачётній, может и гирик под 450, 500 будет самое то.
Оффлайн m1g0r
  • г. Тернополь, Украина
« Ответ #4 : 06 Октябрь, 2008, 12:19:57 pm »
Всем привет. Гирич тестили уже? Цена вкусная, себе на харикейна 550 хочу :)
GAUI Hurricane 550 EP + Rotorworkz Frame Conversion (silver FG) Scorpion 4025 890kv + Hobbywing 70 H
« Ответ #5 : 06 Октябрь, 2008, 12:41:17 pm »
На 600нитрыче, вполне достойно трудится
Оффлайн m1g0r
« Ответ #6 : 06 Октябрь, 2008, 12:46:33 pm »
сенкс, а с какой сервой на хвосте? с DS520?
« Ответ #7 : 06 Октябрь, 2008, 16:59:41 pm »
JR8900G
Оффлайн Piranha
  • My name is Дима
« Ответ #8 : 06 Март, 2009, 19:33:47 pm »
Гирик этот великолепно у меня на пятисотке работал, а вот сейчас всязи с нехваткой гироскопов на душу моих вертолетов (С атома 750й Элайн снял и воткнул в 250го Рэкса) Поставил сей красненький гирик в Атом, правда пришлось влезть ему в чрево и удлинить провода немного, посмотрим как оно с Атомом летать будет :)
