Тема: появилась в продаже Futaba 12FGH Modules 2.4G with Receiver R6014FS  (Прочитано 2044 раз)
Оффлайн Andrei_S
« : 18 Май, 2008, 19:30:00 pm »
у нашего тайваньского друга по цене 994 уя.
характеристики следующие
12FG Specifics:
?G3 2048 resolution
?30 model memory — up to 1,882 models with a 1GB SD card
?Combines airplane, glider, and helicopter programming
?Supports 13 wing types, 3 tail types, and
?8 heli swash types
8 total flight conditions (7 plus the default)
?Variable Dual Rates (VDR)
?Servo grouping for servo synchronization
?Digital trims on all 4 main channels
?7.2V 1700mAh NiMH transmitter battery
?Battery charging jack
?Ergonomic rubber grips
12FG System Overview:
?Quad-bearing gimbals
?27 preset model types, with built-in shortcuts
?Newly designed “joystick” button and Dial-N-Key editing for easier menu navigating
?Ultra-precise tuning in .5% increments
?Front-mounted slider switches for easier access
?255 x 196 LCD Screen with Adjustable Contrast
You get all this with the 12FG:
?R6014FS 2048 Receiver
?Heavy-Duty Switch Harness
?7.2V 1700mAh NiMH Transmitter Battery
?1500mAh Receiver NiCd Battery
?Futaba Orange Transmitter Neck Strap
