Тема: ICE HV 120 NOTICE July 25, 2011  (Прочитано 6824 раз)
Оффлайн McMaxicus
« : 26 Июль, 2011, 00:49:35 am »
Тут письмецо упало от Кастловцев - может кого заинтересует - про замену сабжевых регулей:
Hello all,
While Castle takes all controller failures seriously, many have felt that our response to the incidences of failures in our Phoenix Ice 120HV was taking too long. We didn't make any official statements as we couldn't identify any particular pattern or cause for the failures. Our Repair Dept. keeps track of our returns - for any reason -- and the returns of the 120HV were actually very low; less than 3%.  We generally see more than that rate of return just from crash damage unrelated to the controllers. Given that we've produced more than 10,000 of these controllers, a low percentage of failure still results in a lot of upset customers.
We've recently determined that some, again some, setups stress particular components in a way that causes the controllers to fail instantly.  The failure mode allows a complete short circuit to occur.  Our controllers are designed to carry high currents with as little resistance as possible.  This is advantageous when the controllers are operating properly, but this leads to extreme currents and heat when the controllers fail.  As the ICE controllers are encapsulated in metal heatsinks, this heat is further concentrated such that physical injuries or property damage may occur.
Our engineers have tested a hardware modification that greatly reduces the risk of this particular failure.  We do not recommend using Phoenix Ice 12HV controllers until they have been modified to this new standard.
Please return any 120HV controllers that you may have for one that has this modification.  There will be no charge for this exchange.
Please advise anyone using a 120HV controller of this notice.
REPLACEMENT PROCEDURE
Click this link and follow the directions to process your return.
North American customers please ship to Castle in Kansas via a traceable delivery service:
    CASTLE CREATIONS, INC
    120HV SERVICE / Service Department
    540 N.ROGERS RD.
    OLATHE, KS 66062
    European customers may return their controllers via a traceable delivery service to our new European repair center:
    CASTLE CREATIONS EUROPE BVBA
    120HV SERVICE
    GEELSEWEG 80
    2250 OLEN
    BELGIUM
    Please be sure to include a copy of the order confirmation in your package.
NOTE: For purposes of fast turnaround, you will be sent another Phoenix Ice HV 120 controller. Remove all connectors, etc. from your ESC before shipping as they will not be returned with your replacement controller.
Our Technical Support and Repair staff do not have any additional information, calling them will only lead to additional frustration for all involved.  We will advise you via email of the expected shipment date for your return.
We apologize for any problems this matter may have caused, and we hope that our candor and willingness to repair these controllers will help maintain your trust in our products and service.
Thanks,
Team Castle
« Ответ #1 : 26 Июль, 2011, 10:18:26 am »
По сути объявлена бесплатная замена всех ICE 120HV. Что сказать, хоть и неприятный косяк с регулями, но Кастл - молодцы, поддерживают свой товар.
Оффлайн palek
    • Артём
    • Владимирович
« Ответ #2 : 26 Июль, 2011, 11:33:54 am »
Хоть и нет проблем, но на халяву надо менять! :)
Кто с англицким дружит - чё там нужно для этого сделать?
GMT
« Ответ #3 : 26 Июль, 2011, 11:40:45 am »
Вот это по нашему!!!!!!  :D :D :D :круто: :круто: :круто:
Оффлайн palek
    • Артём
    • Владимирович
« Ответ #4 : 26 Июль, 2011, 11:55:37 am »
 :D
За всё время, которое я занимаюсь вертолётами - впервые вижу такое щедрое предложение! Грех не воспользоваться. Молодцы кастловцы! У кого-то из них наверно тойоту отзывали.  :D
Так хочу поменять, аж кушать не могу! :D
« Ответ #5 : 21 Август, 2011, 05:33:30 am »
Кастлы пошли дальше.
Теперь под переделку идут и другие контроллеры:
Phoenix ICE HV 60
Phoenix ICE HV 160
Phoenix ICE HV 160 LITE
Phoenix ICE HV 80
Mamba XL
Phoenix ICE HV 120
Hydra ICE HV
Афигеть  ::)
Мне их жаль.
Оффлайн DmitryG
« Ответ #6 : 21 Август, 2011, 05:53:19 am »
Был крупный пожар вызванный их контроллером. Сейчас на них подан много миллионный иск. Если они его проиграют, то возможно полсе этого их уже не будет существовать. Тем не менее решили отозвать свои контроллеры, чтобы ещё один иск не получить.
Оффлайн pxkeeper
  • Кирилл Карнаух
« Ответ #7 : 21 Август, 2011, 08:16:54 am »
Что за пожар? Что сгорело?
Не представляю как можно регулятором крупный пожар устроить, если только не специально  ::)
Logo 600, MA Furion 6
Оффлайн GregoryS
    • Григорий
    • Скоблин
« Ответ #8 : 21 Август, 2011, 14:49:35 pm »
Интересно, а сгоревший регуль старой версии они бесплатно поменяют? :-[
« Ответ #9 : 21 Август, 2011, 15:06:32 pm »
...вполне достаточно человеческих травм от одного регуля... :(
...а при серьёзных ожогах с последствиями  сумма иска может быть запредельной...
« Последнее редактирование: 21 Август, 2011, 16:49:34 pm от Kulichik »
« Ответ #10 : 21 Август, 2011, 15:23:53 pm »
Скорее всего - это были не модельки? Есть детали?
« Ответ #11 : 22 Август, 2011, 15:55:57 pm »
На RCGroups появился очень любопытный пост про причины возгорания Кастла: http://www.rcgroups.com/forums/showthread.php?t=1450849&page=7#post19027189. Сбоит драйвер ключей.
Ниже есть ответ босса Кастла о том, что драйверы в последних выпусках имеют отклонение от спецификации и вызывают короткое замыкание ключей на входе и выходе.
Чуть ниже  вскользь упоминаются планы о разработке регуляторов до 15S-20S. Кастлы заказали разработку драйвера ключей по собственной спецификации, и уже получили новые микросхемы. Я так понял, что текущая сервисная кампания направлена на замену платы управления, на новую с новыми драйверами ключей.
Оффлайн Jazzman
    • Деев
« Ответ #12 : 23 Август, 2011, 11:56:47 am »
Кто-нибудь отправлял CC запрос на ремонт по отзыву? Я отправил вчера, но пока без привета.
Оффлайн Sergeev
    • Сергеев
« Ответ #13 : 23 Август, 2011, 14:08:39 pm »
Отправил - также без ответа.
Оффлайн Jazzman
    • Деев
« Ответ #14 : 23 Август, 2011, 15:34:12 pm »
У заграничных коллег на хелифрике процесс замены идёт. Похоже, мы либо в пролёте, либо в очереди.
