Тема: Spektrum Voltage Regulator VR6010  (Прочитано 2930 раз)
« : 18 Апрель, 2008, 10:33:59 am »
БЕК от Спектрума
BEC     VR6010
Manufacturer    Spektrum
Type    Switching Regulator
Max Input Voltage                      10V
Min Input Voltage                       6V
Output Voltage                               6V
Output Current                               10A Continues/16A Peak
Dimensions                                 40mm x 30mm x 30mm
Weight                                           50g
Max #Servos                                15-20 Analog, 10-15 Digital
Connector                                  Universal JR/Hitec/Futaba
Applications                                    Airplanes/Helicopters
The VR6010 is designed for high-current draw applications, such as giant-scale airplanes with multiple high-current draw servos. Spektrum's model VR6010 6V/10A regulator allows the use of 2-cell Li-poly or 5 to 8 cell NiCD and NiMH receiver packs to be used to power your onboard radio system. A single VR6010 regulator provides 10A continuous current (16A peaks) making it ideal for most high-current draw applications. For heavy duty applications two VR6010's can be used to provide 20A continuous and up to 32A peak power. The VR6010 is ideal for use with Spektrum's AR9100 series PowerSafe receiver and comes pre-wired with EC3 connectors.
Features:
- Brings higher voltage packs within the operating limits of most servos
- Delivers a steady 6V ensuring consistent performance throughout the discharge cycle of the battery
- Includes a fail-on switch and 16-gauge heavy duty input and output wires with EC3 connectors
- Drop in addition for the AR9100
- Cooling fan provides additional current handling capability
- Convenient mounting lugs
For best results, ensure that the all BECs are installed at least 2" (50mm) away from your receiver and antenna.
цена вопроса 75 баксов
Оффлайн AlekseyM
« Ответ #1 : 18 Апрель, 2008, 16:13:49 pm »
так а ценичек и где купить?
Alex
« Ответ #2 : 18 Апрель, 2008, 16:26:34 pm »
Магазин:  espritmodel
Цена: 75$ ///:-)
