Тема: UH-60 500 Scale Fuselage from Align  (Прочитано 2626 раз)
Оффлайн a-korenev
    • Коренев
    • ++К
« : 23 Май, 2011, 11:14:21 am »
UH-60 500 Scale Fuselage HF5006
$410.99
Instructions:
? The UH-60 Blackhawk helicopter has been popularized by Hollywood productions, leaving fans with impression of its role as wartime payload carrier. This highly detailed Blackhawk scale fuselage with camouflage paint scheme is a great opportunity for the collectors and enthusiasts alike.
? The complete kit includes special carbon side frames, scale 4 blades rotor system, scale elevated tail rotor system, and even functional cabin doors. The detailed scale features of this fuselage surely will make any imaginary movie scenario come true. Time to send your Blackhawk out to the battle field for your own search and rescue mission!
? 3G flybarless system is not included with this kit, and need to be purchased separately.
? UH-60 Scale Fuselage suitable for T-Rex 500 models.
Features:
? Special carbon side frames
? Elevated tail rotor assembly
? Scale landing gear assembly
? Functional cabin doors
Specification:
? Body length:1085mm
? Body width:244mm
? Body high:265mm
? Weight:890g
Accessory:
? Fiberglass main frames (R/L) x 2
? Tail boom (?15x?16?152mm) x 1
? Torque tube (154mm) x 1
? Linkage rod (B) (?2?180mm) x 1
? Plate x1
? Torque tube drive gear assembly x 1
? Angled tail transmission assembly x 1
? Tail rotor control arm x 1
? Linkage ball A (T2.6?3.5) x 2
? Collar screw x 1
? Ball link x 4
? One-way Bearing Grease x 1
? Long Torque Tube Drive Gear x 2
Пилот выходного дня
« Ответ #1 : 23 Май, 2011, 21:19:14 pm »
Пораньше бы они его выпустили, я как раз "черного ястреба" хотел брать.... Теперь вот локти кусать... Меняю аирвольфа на блекхока, а?  :D
Рама то какая хитрая, как они балку опустили оригинально, да еще и вал!!! Вот это уже правильный подход.
« Ответ #2 : 08 Сентябрь, 2011, 21:06:12 pm »
красава, можно и по самолетному взлетать и покататься, люблю вертушки с шассями.
[youtube]http://www.youtube.com/watch?v=4HpEOgW35gA[/youtube]
