Тема: Гироскоп Hitec HG-5000 и серва для него HSG-5083MG для 450 вертов  (Прочитано 3056 раз)
« : 14 Сентябрь, 2007, 12:25:28 pm »
NEW MICRO GYRO & HIGH SPEED DIGITAL TAIL ROTOR SERVO
Hitec is proud to announce the HG-5000 micro heading lock gyro with the
“extreme speed” HSG-5083MG Digital Micro Tail Rotor servo. The HSG-
5083 was built specifically for the HG-5000 to obtain optimum performance
in the T-Rex 400-450, Helimax 400-450 or similar class of electric helis. At
0.35 oz the HG-5000 is very light and small, yet yields performance equal or
better than any other Gyro available. Stock #44192 (Gyro & servo) | MAP $179.99
HS-5000 GYRO
• Optimized High Response Narrow Band Hitec Signal
• Best with Hitec HS-5083MG
• Universal Signal Selectable (both Digital & Analog)
• Precision Control Technology for Heading Lock
• Auto Detection for any Transmitter & Receiver
• No initializing Time - Powering up in Head Lock Mode
• Extreme Tolerance against Disturbance and Vibration
• Advanced Real Time Sensor for Drift Removal
• Remote Gain Adjustment
• Light Weight & Compact Size
• Self Diagnosis Function
• Simple and Vivid LED Display
• Easy Data Setting
• Low Power Consumption (20mA)
• Size: 0.86” x 0.86” x 0.43” | Weight 0.35 oz
HSG-5083MG
• Micro Digital Servo for HG-5000 use only
• Optimized for 400-450 class EP Helicopters
• All Metal Gear (1st MP Gear)
• Size: 1.14” x 0.51” x 1.18”
• Weight: 0.74 oz
• Torque at 4.8V: 20.85 oz.in
• Speed at 4.8V: 0.07 sec/60 deg
• Fastest Servo Hitec has ever made!
-Replacement MP 1st Gear Part # 55023
-Replacement Gear Set Part # 55021
-Replacement Case Part # 55421
Говорят конечно по английски, но вроде всё понятно
