Тема: New V-Bar Control Panel  (Прочитано 3166 раз)
« : 08 Февраль, 2008, 08:09:24 am »
 Микадо на месте не стоит и для поклонников системы V-BAR, сделали чудный девайс для настройки этой системы.
V-Bar Control Panel
The days of carrying an expensive laptop to the flying field
are over, the new V-Bar Control Panel is the easiest and most
practical way of programming the V-Bar. The V-Bar Control
Panel is connected directly to the V-Bar via cable and allows
you to program the V-Bar with necessary data such as initial
set-up and parameter adjustment right at the flying field. The
panel features an ergonomically correct turning knob and push
button which have been integrated for easy operation, an SD
card for loading model data or updating set-up software, and a
high-contrast display which is readable even in bright sunlight.
The SD card can also be used to transfer model data to another
pilot’s helicopter.
• easy-to-use set-up software
• high-contrast graphics display
• easy handling via turning knob and push button
• loading and saving of model set-ups via SD card
• updates via SD card
#4152 V-Bar Control Panel
