Тема: Виртуальная комплектация Т-Рекс 500  (Прочитано 19476 раз)
Оффлайн Piranha
  • My name is Дима
« Ответ #30 : 12 Март, 2008, 15:21:09 pm »
PS
отя эта инфа не сильно достоверна и вот вроде опозитное мнение
Who was the engineer your buddy spoke with? Name?
3400G works fine with the 770 gyro. The servo has nothing to do with DRIFT issues if you are having that problem. And if your piroette rate is not balanced then you have a set up issued. Call it differential in your t/r that needs to be adjusted mechanically or thru radio software...your choice.
I worked alongside with Horizon to make the 3400G. Actually there were about 3 of us that were involved in the development of the 3400G. I'd like to discuss this info with the engineer you say said this.
The 3500G is NEW - BRAND NEW. It is being packaged with the 770 since folks want NEW stuff and not "yesterdays” high end servos. The 3500G is faster than the 3400G and it has less torque as well. Speed is what people want. 3400G was very good on the t/r of mini size helis...now the 3500G will be even better. Also worth noting is the JR 285's were also packaged in the mini heli performance kit from JR with the 3400G. As you may suspect you will also see the 285MG servo packaged with the 3500G too in the future.
Оффлайн Andrei_S
« Ответ #31 : 12 Март, 2008, 15:58:09 pm »
c 770ой и 3400 хвост действиельно плавает.
у меня эта связка была
« Ответ #32 : 12 Март, 2008, 16:23:58 pm »
JRC3500G : JR DS3500G Digital Servo (Ideal for T-Rex 500)
JR DS3500G High Seed Servo this is ideal for the Trex 500 cyclic's or equally as good as a High speed tail servo. Torque: 2.0 Kg/cm, Speed: 0.07s/60, Weight: 26g
Интересно а двухкилогаммовой машинки хватит на автомат перекоса?
« Последнее редактирование: 12 Март, 2008, 16:35:17 pm от tim001 »
« Ответ #33 : 12 Март, 2008, 16:49:44 pm »
Вот будет машинка классная под Рекса 500 жаль доступна будет только летом
DS3517MG High Speed Mini Servo MG
Specs
Type:Digital High-Speed Metal Gear Mini Servo
Torque:42 oz/in @ 4.8V, 51 oz/in @ 6V
Speed:.11 sec/60 degrees @ 4.8V, .09 sec/60 degrees @ 6V
Dimensions (WxLxH):.58"x1.02"x1.3"
Weight:1.04 oz
Motor Type:Coreless
Connector Type:JR
Gears:Metal
Оффлайн ugh
    • Герман
« Ответ #34 : 12 Март, 2008, 18:01:02 pm »
Мда, народ, быстро у вас тут все меняется... Похоже я еще пару месяцев подожду, пока устаканится... :)
А нету инфы, что 500-ые будут в версиях SE? Чтоб потом с апгрейдами не париться...  ::)
Оффлайн Jocker
« Ответ #35 : 12 Март, 2008, 18:17:24 pm »
Голова металл, рама карбон, что еще нужно-то? Только рычаги микшеров докупить ($24) и все. Можно еще проставки рамы в которых подшипники вала ОР тоже на металл ($44). Хвост имхо это уже фетишь, три раза бил верт, два раза в полный хлам, все разы хвост падения пережил.
« Ответ #36 : 12 Март, 2008, 18:39:32 pm »
По слухам к концу лета выйдет версия с валом на ХР. Не ждать, неохото, лето на дворе. Алигн будет не Алигн, если апгрейдов не будет-это их философия.
По поводу хвоста пока буду летать с пластиком, потом поставлю апгрейд с валом.
Оффлайн Jocker
« Ответ #37 : 12 Март, 2008, 18:48:06 pm »
Интересна цена вала, если сопостовима с ремнем, то конечно вал интересно попробовать.
« Ответ #38 : 12 Март, 2008, 19:19:57 pm »
не, апгрейд будет стоить денег. Но мне нравится вал, поэтому пойду на финансовые жертвы. А так из апгрейдов-  проставки рамы в которых подшипники вала ОР и слайдер опционный.
Оффлайн Piranha
  • My name is Дима
« Ответ #39 : 13 Март, 2008, 09:43:32 am »
Самое интересное что в Пилотаже оказывается уже есть JR3500G во млин оперативно просуетились :) похоже с комплектацией хвоста вопрос решен JR770G+3500G
от с сервами на перекос пока не определился, толи ждать и искать Z3650 толи не бычиться и поставить 9650?
« Ответ #40 : 13 Март, 2008, 10:07:54 am »
Z3650 и DS3517MG по характеристикам и цене практически братья близнецы , разницу я не увидел поэтому решил не дожидаться DS3517MG и буду искать Z3650
Оффлайн Andrei_S
« Ответ #41 : 15 Март, 2008, 17:11:27 pm »
а как вам вот такие варианты
в голову
HG-D251MG
• Power : 4.8V ~ 6.0V
   • Speed : 0.15s/60°, 0.12s/60°
   • Torque
                 4.8V--Dynamic torque: 4.8kg.cm(66.65oz.in)
                 6.0V--Dynamic torque: 5.6kg.cm(77.76oz.in)
   • Size : 30.0X13.0X33.30 (1.18X0.51X1.31in)
   • Weight : 24.40g (0.86oz)
   • Application : Micro electric helicopters(T-rex 500), Glider
в хвост или оно же в голову
по крайней мере по килограммам вроде канает
HG-D261HB
   • Speed : 0.07s/60°, 0.06s/60°
   • Torque
                 4.8V--Dynamic torque: 2.4kg.cm(33.32oz.in)
                 6.0V--Dynamic torque: 3.6kg.cm(49.99oz.in)
   • Size : 30.0X13.0X33.30(1.18X0.51X1.31in)
   • Weight : 20.65g (0.72oz)
   • Application : Micro electric helicopters(T-rex 500).
ценники должны быть гуманные
« Последнее редактирование: 15 Март, 2008, 17:24:08 pm от Andrei_S »
« Ответ #42 : 16 Март, 2008, 09:05:27 am »
http://hobbyalley.com/store/category/14/130/Servos/ здесь есть сервушки JR z3650 по 79, а я блин по 85 заказал. Не знаю правда на Россию высылают али нет.
« Ответ #43 : 16 Март, 2008, 09:07:03 am »
HG-D261HB редуктор не металл, а так характеристики класс, еще вопрос, где редуктора покупать
Оффлайн ugh
    • Герман
« Ответ #44 : 18 Март, 2008, 16:11:41 pm »
Ребята, берегитесь - Piranha явно заразный! :D У меня тоже ломки начались.  ::) До этого как-то более расслабленно думал о приобретении...
Т.к. со свободными деньгами сейчас напряг, возник вопрос, не распотрошить-ли мне слегка 450-го, ради старшего братца?!  :-[
В связи с чем вопросы:
1. Пиранья пишет, что на перекосе 9650, а на хвосте 9257 (если не ошибаюсь). У меня на хвосте 450-го тоже стоит 9650, если докупить еще 2 таких и 1 9257, то как всё это вместе собирается? По идее 9650 надо на 6в ставить, чтоб скорость повыше была, или 9257 нормально 6в переваривает? Или регулятор алайновский можно с 6в переключить на 4.8в?
2. Может лучше и на перекос ставить 9257? Или все-же JR? Просто, подешевле хотелось-бы, но не в ущерб, так сказать...
3. Пойдет ли, пока учусь гира Gy401-ая? Снял бы ее пока с 450-го...
Вопросы может и наивные, но как-то спать не дают...
« Последнее редактирование: 18 Март, 2008, 16:13:53 pm от ugh »
