Тема: апгрейды для T-Rex 450v2  (Прочитано 3248 раз)
« : 10 Ноябрь, 2007, 09:10:01 am »
Родные демпферы у Рекса очень мягкие, здесь можно прикупить более достойный вариант, для версии V2
http://www.readyheli.com/TREX_V2_Head_Dampener_Upgrade_Red_Dampers_by_Tru_p/dampeners2.htm
This upgrade replaces the stock o-rings...pack of four (set of two complete sets). The advantages of these dampeners is simple. They are able to produce a more responsive and tighter head dampening response by filling the entire dampening area of the head block with material. The dampeners are designed specifically for the T-Rex 450XL/SE V2 head block and spindle, giving a tight dampening solution without needing to over-compress the rubber with spacers. Also, because of their shape and material, the Pro T-Rex Head Dampeners are able to last much longer. These will not fit the V1 SE/S/SA/XL/X.
Should your product come with any moudling flash:
1. Poke a small hole in the flash with an X-Acto blade.
2. Push the spindle through the damper stretching the flash onto the spindle.
3. Take the X-Acto blade and cut around the spindle next to the damper.
Another quality Mike Trueblood Engineering Product, Exclusive to Ready Heli.
« Ответ #1 : 26 Ноябрь, 2007, 10:49:07 am »
Ну вот и пришли демпфера, на вид кусок силиконовой трубки красного цвета, брат уже поставил и обкатал, получше прилично   по сравнению со стоковыми демпферами.
Оффлайн Andrei_S
« Ответ #2 : 27 Ноябрь, 2007, 17:07:00 pm »
вот еще типа суперблатные демпефера на тирекса
http://rchover.com/inc/sdetail/61689
« Ответ #3 : 19 Январь, 2008, 07:06:23 am »
Weighted tail blade grips are proven effective and functional on full sized helicopters and RC helicopters.
The G-Force weighted CNC tail blade grips are a bolt-on upgrade with performance that you can feel.
 Грибы на Рексика, ну и типа пишут какая замечательная штука.
The weights are used to reduce the momentum of the blades that have a tendency to center themselves. These natural forces put extra load on the tail servo and reduces its response.
The G-Force tail blade grips incorporate weighted flanges closest to the center near the hub and linkage point for best performance. The flange is also pre-tapped so you can add more weight if necessary to fine tune your setup.
The 450 version (Part #GFT6010) will fit both T-Rex 450 V1 and V2.
A V2 hub is required.
