Тема: DN Power Micro-Controlled LiPo/Li-Lon G2 Balance Charger Balancer  (Прочитано 2991 раз)
« : 10 Ноябрь, 2007, 09:03:27 am »
Если в ваши планы не входит использовать батареи больше 4S, такой вот недорогой относительно зарядник-балансир
 DN Power Micro-Controlled LiPo/Li-Lon Balance Charger w/ LCD Display
The battery shown is not included and is illustrated for demonstration purposes only.
It's simply the best balance charger you can have now! This is designed to go with our new DN Power Lipo's or any other Lipo/Lion up to 4S...
You simply CANNOT beat the price for a all-in-one charger/balancer unit!
This will charge and balance any 1-4S Lip/Li-Ion Battery and can accomodate any type charge plug with its universal wiring setup...it also includes free balance adapters which can be modified to balance your batteries....
Product Features:
1. Input voltage: DC 11V~15V. The working electric current is less than 6A when it is charged in full load. The current of the fuse is 10A which could prevent short circuit.
2. The charge current is 0.2A~2.0A and the adjusting step is 0.2A which can be set by the buttons on the board.
3. Controlled by 4 separated internal micro computers. Charge 1S-4S battery separately. not like other serial charging + balancer setups on the market. More efficient.
4. 4 separated JST style charging ports, one general charging port.
5. Big LCD display. real-time displays voltage and charging processing clearly and separately.
6. Low voltage protection. Charger won't charge any cell if voltage is lower than 2.7v.
7. Automatically stop charging when it's done. A buzzer will call.
8. 4 separated parallel charging circuits ensure your battery is 100% fully charged. Higher efficiency.
9. Charge mode of the balanced parallel connection
    A. Charge in parallel connection for one single cell or four single cells at one time
    B. Charge in parallel connection for a pile of two series-wound lithium cells or two piles of two series-wound lithium
    cells at one time
    C. Charge in parallel connection for a pile of three series-wound lithium cells or one single lithium cell at one time
    D. Charge in parallel connection for a pile of four series-wound lithium cells
10. Working rating: -20 ~ 60 C
11. Fully circuit protection: protect the charger and battery even when connect the battery or the power supply reversely. 12. General charging port will allow you charge any lipo battery which has balanering leads.
Фото:
« Последнее редактирование: 05 Октябрь, 2008, 04:01:38 am от SkyForever »
« Ответ #1 : 10 Ноябрь, 2007, 16:31:58 pm »
Интересная зарядка, похоже она работает по независимым каналам ... надо уточнить.
То есть, если это так, то ей можно заряжать независимые батареи (2S + 2S или 3S+1S )и прикупив вторую (третью) - заряжать МНОГО-S батареи ... :o или скажем 3S+3S+3S одновременно ... ;) ...а главное абсолютно независимо каждую банку!
« Последнее редактирование: 10 Ноябрь, 2007, 16:39:37 pm от AlexSr »
Оффлайн Serj
  • э...
« Ответ #2 : 12 Ноябрь, 2007, 13:25:20 pm »
вот только ток заряда маловат :(
