Тема: Новый Scorpion Tribunus 14-200A ESC SBEC!  (Прочитано 27477 раз)
« : 01 Март, 2017, 22:36:23 pm »
Scorpion выпускает новый регулятор Tribunus 14-200A ESC SBEC
Отличный подарок на 8-е марта, мужики!  :D
Подробности тут:
http://www.scorpionsystem.com/news/Tribunus14-200
Scorpion Tribunes 06-120 ESC SBEC and Scorpion Tribunus 06-120A ESC OPTO have proven themselves by very successful from the pilots feedback.
Are you ready to take your flying to the next level?  Scorpion's brand new Tribunes 14-200A ESC SBEC is available for pre-order NOW! It is 14S HvLi ESC with built-in BEC keeps wiring clean, allows for easy setup, and is adjustable from true DC-DC 5.3V-8.3V BEC to power servos and receiver with 10A continuous and 20A peak! There's even room for a 40mm cooling fan to be bolted onto the ESC heat sink, and plugs directly into the side of the SBEC. With our new governor design, internal and external are also available. Built-in protection like current, voltage, temperature, capacity protection and more will keep your ESC and aircraft safe. Enjoy new features such as data logging, Morse code indications, Android apps support, telemetry, and even remote settings compatible with Mikado V Control and more. Why fly old technology when you can be the first person in town to use the latest and greatest!
With the new V Link II cable (Optional) supported by Windows XP, Windows 7,8 and 10, you can always keep your ESC updated with the latest firmware, and make changes to your settings with ease!
The newly updated programming software has been hugely improved upon, and makes setup and tuning easier than ever. Pre-Order your Tribunes 14-200A ESC SBEC before 8 March 2017, and get a FREE V-Link II cable ! It's never been easier to program an ESC with your computer, so don't miss this 1-time Special offer!
Weighing in at just 260 grams, this sleek, compact power house is just what your 12/14S helicopter or airplane needs to help elevate your flying game. Don't be the last guy in your area to have this bold, next-generation Electronic Speed Control, so order your Tribunes 14-200A ESC SBEC from Scorpion Power System today!?
Pre-Order now and we will delivery after 8 March 2017 with the FREE V-Link II cable.
MSRP:USD449.99
« Ответ #3 : 02 Март, 2017, 23:45:06 pm »
А вес в 260 гр это не много? :-\
Да это просто  "пушинка" по сравнению с аналогами!  :ура:
HobbyWing-200A весит 300 грамм (кажется и вес указан без проводов) и при этом не имеет BECа на который уйдет еще 50гр!
Kosmik-200A с проводами и гайками - 400грамм (только что взвесил новый)
Производители взяли моду указывать вес как им вздумается, но Scorpion указывает вес со всеми проводами и их полной длинной (это я также проверю, когда он приедет).
В любом случае, он практически вдвое легче своих одноклассников!!!  ;)
« Последнее редактирование: 02 Март, 2017, 23:50:22 pm от Nik Nik »
Serg78
« Ответ #4 : 03 Март, 2017, 00:21:00 am »
Еще бы гувернёрил как космик, цены бы ему не было :)
Очень интересен результат испытаний!
Ценник для таких данных в принципе в адеквате.
Оффлайн nik1
    • Гончаров
« Ответ #7 : 03 Март, 2017, 15:46:05 pm »
Вес конечно знатный, если еще будет путево работать , то вобще гуд
« Ответ #8 : 03 Март, 2017, 16:10:16 pm »
Буду с любопытством наблюдать, как у Николая эта лайба пиликать будет  ;)
Надеюсь у Скорпа в этот раз все получится, ибо предыдущий его регуль был не регуль  :D
« Ответ #9 : 03 Март, 2017, 18:38:52 pm »
Ага, хоть сразу запасные покупай!
Да ладно вам,а то космик спасает кондюки спрятанные в корпус  :D
  Если "удачно"  приложиться -даже бронежилет не спасает -доказано нашими военными  :D
« Ответ #10 : 03 Март, 2017, 18:42:00 pm »
Тем не менее именно скорп отменно работал с внешним гувером ,его собственный видимо требует познаний в искусстве камлания :)
« Ответ #11 : 04 Март, 2017, 09:23:13 am »
 ::) | 8-( :hunt:  :)
« Ответ #13 : 31 Март, 2017, 21:21:32 pm »
Давай быстрее на борт его и в небо !
Не томи. Интересно узнать, регуль это или кофеварка.
« Ответ #14 : 31 Март, 2017, 21:28:43 pm »
Тоже жду отчета Николая!А вдруг будущие все таки наступает! ;)
