Тема: GP750 Head Lock Gyro Combo (GP750+DS420) Align  (Прочитано 4227 раз)
« : 10 Ноябрь, 2008, 13:02:29 pm »
Алигн штампует гирики, что бабушка пирожки печёт. Вот ещё слепили  и серво в комплекте под 250
GP750:
?Utilizes Silicon Micro Machines (SMM) sensor with excellent stability to dramatically reduce in-flight tail drifts.
?Utilizes AHTCS (Active Helicopter Tail Control System) to compensate any drift caused by wind direction and force, as well as unintended yaw induced by helicopter itself during flight maneuvers.
?Tailor made specifically for use with high speed digital rudder servos. This gyro festures high sensitivity and minimal reaction time, fully utilizing the potential of modern high speed digital rudder servos.
?Suitable for all sizes of helicopters, from micro indoor to large 90 size glow helicopters.
?Metallic dampening plate built into bottom gyro casing, dramatically increasing anti-vibration and anti-interference abilities.
?Features 1520?s pulse wide and 760?s narrow pulse wide frame rate.
?Digital/Analog servo switchable.
?Reverse switch.
?Rudder servo travel limit adjustment (ATV).
?Mode switch for large/mini helicopter.
?Delay adjustment.
?Gyro locking mode and gain can be adjusted remotely from the transmitter.
1.Mini/Micro heli mode, suitable for T-REX250/450(“STATUS” Red);Medium/large heli mode, suitable for T-REX500/600/700(“STATUS" Green)
2.There are 3 kinds of 760?s narrow pulse wide servos on the market, including Futaba S9251, S9256, BLS251.
DS420:
?Fast speed and high torque. High strength metal gears with high precision and durable structure characteristics.
?Aluminum alloy mid case construction for instantaneous heat dissipation, maintaining servo’s high efficiency.
?Supports digital & analog control signal.
?Precise servo, suitable for T-Rex 250 rudder use.
   GP750 Ratings:
?Operating Voltage:DC 4.5~7V
?Current Consumption:<80mA @ 4.8V
?Angular Detection Speed:500 degrees/sec
?Operating Humidity:0?~65?
?RoHS certification.
?Operating Humidity:0%~95%
?Size:26x25x11mm
?Weight:14g
DS420 Ratings:
?Stall torque:0.75kg.cm(4.8V)
                   1.0kg.cm(6.0V)
?Motion speed:0.08sec/60°(4.8V)
                     0.06sec/60°(6.0V)
?Rating voltage:DC 4.8-6V
?Temperature range:-20°C~+60°C
?Dimension:22.8 x 12 x 25.4mm
?Weight:12.7g
Accessories:
?Double sided tape x 2
?Servo rudder piece x 4
?Set screw x 1
?Tapping screw for servo x 2
И теперь есть режимчик, в котором можно учесть размер  вертушки и скорректировать работу гироскопа.
« Ответ #1 : 10 Ноябрь, 2008, 14:58:40 pm »
Не нужно было торопиться с покупкой 700 гирика для малышей.
« Ответ #2 : 10 Ноябрь, 2008, 16:10:08 pm »
Вот же, а, маркетологи  :D
Забавно - на серву не боятся температурный диапазон указать : "Temperature range:-20°C~+60°C"
А на гирик - боятся!   :D Ваащё - никакого! То есть, пользовать его нииииизя, ни при какой температуре!  ;D ;D
Оффлайн Fedor
    • Виталий
    • Федченко
« Ответ #3 : 13 Январь, 2009, 16:14:43 pm »
Добрый день! помогите настроить эту Гиру на 250-м
« Ответ #4 : 13 Январь, 2009, 18:20:44 pm »
Вах у нас 200 только едет с этим гириком, ещё сами не пробовали на этом типоразмере вертов..
« Последнее редактирование: 13 Январь, 2009, 18:27:34 pm от tim001 »
Оффлайн Fedor
    • Виталий
    • Федченко
« Ответ #5 : 13 Январь, 2009, 18:43:42 pm »
Как попробуете, не забудьте рассказать. *BRAVO*
Оффлайн djidai
« Ответ #6 : 05 Март, 2009, 14:02:50 pm »
Вопрос к пользователям 750 от алинга.
я так понимаю это клон JR ? или я ошибаюсь. возможноли пользовать эту приблуду на всех меделях вертов ДВС в том чисте. Хочу прикупить на вырост и цена у неё болеее чем приятная, но отзывов пользователей практически нету, пользуют в основном с 200-250(((
А кто ставил на двс ка она себя показывает, из отзывов на 200-250 держит просто насмерть.
« Ответ #7 : 05 Март, 2009, 14:54:39 pm »
Мне на вращениях, пируэтах не особо понравился.
Оффлайн Piranha
  • My name is Дима
« Ответ #8 : 05 Март, 2009, 19:11:43 pm »
Во-первых Название компании Align в русской транскрипции произносится как ЭЛАЙН, но не как не алинг, алигн итд :)
Во-вторых GP750 это ничей не клон, а самостоятельный девайс, работает ужъ точно не хуже JR770го(мне больше чем ДжиЭрка он понравился), Если Вы не мегасуперпилот как Братья Николай и Тимофей Гончаровы, то этот гироскоп вполне удовлетворит Ваши потребности ;)
« Ответ #9 : 05 Март, 2009, 19:24:00 pm »
Это для тех кому он нравиццо он элайн, а для остальных - алигын  :P
« Ответ #10 : 05 Март, 2009, 19:47:00 pm »
А, это такое произношение у любителей Тундерных Тыгров ?  ;D Или ценителей Хероб ? Нет, наверно у "Авантуристов"  ;)
Все иностранные названия - чужды уху россейскому. Вот и коверкают их, кто как может.  :D
2: Дим. А 750 позиционируется не как для мелколётов? На нитру тоже идёт? И в чём тогда разница с 700-м ?
Оффлайн Piranha
  • My name is Дима
« Ответ #11 : 05 Март, 2009, 20:33:56 pm »
Разница как раз в том что в 750м есть опция выбора -  большая модель\маленькая модель
