Тема: 6v Voltage Regulator w/ 5.1v Gyro Output  (Прочитано 2065 раз)
« : 25 Октябрь, 2008, 09:16:32 am »
Вот ещё интересный регуль, напряжение от 5,2в до 8,5 можно настроить и плюс на хвостовую серву выход на 5,1 в.
Similar to our 6v and 6.2v Voltage Regulator, our new Adjustable Voltage Regulator is going to be another top runner for Voltage Regulator needs. This unit will allow upwards of 11.1v input from an array of battery technologies, (Ni-Cd, Ni-Mh, Li-Ion and Li-Po). Output Voltage is user adjustable within a range based on the input voltage supplied to the unit. With a 7.4v input, the Voltage range can be set anywhere from 5.2v - 7v and with an 11.1v input, you can go upwards of over 8.5v.* The best way to set the Voltage Output is through an already connected Electronic Device (ie... GV-1) that displays Voltage. Otherwise any Volt Meter would work fine.
The Unique design of the Heatsink with ULTRA-THIN Fins allows for super fast dissipation of heat and makes Installation a breeze due to not needing air-flow over the Heatsink. Unlike the other versions of Voltage Regulators we carry, this unit has wires protruding from only one side.
Also built into the same unit is a 5v relay for use with Gyro / Tail Servos that are suggested to use an input of 4.8v - 5.1v.
This compact and light-weight Voltage Regulator will definatley exceed your expectations!!!
Standard - comes with standard 6" leads (universal).
Add 2 Rx Outputs - same as standard with 2 rx output leads.
Add 16AWG Deans - same as standard with 6" 16awg deans battery input.
Add Both - same as standard with 2 rx outputs and 6" 16awg deans battery input.
Technical Information
Min. Input Voltage:                                 7.4v
Suggested Input Voltage:                         7.4v - 11.1v*
Main Output Voltage w/ 7.4v:                 Adjustable 5.2v - 7v @ 10A
Main Output Voltage w/ 11.1v:                 Adjustable 5.2v - 9v @ 10A
Gyro/Tail Output Voltage:                         Constant 5v @ 1.5A
Max. Main Amp Rating:                                 16A
Max. Gyro/Tail Amp Rating:                         3A
Heatsink Material:                                 Aluminum
Length of Lead Plugs:                                 6" Each
Plug Type:                                               Universal
Size:                                                         60mm x 30mm x 9mm
Weight:                                                 33.5g
nik-50
« Ответ #1 : 04 Март, 2011, 03:43:52 am »
Just-Heli JH 20A PRO Voltage
http://www.century-rc.com/ecs/news_show.php?news_id=225
Весьма дешевле и не менее интересен чем Scott Gray Reactor X2 15A/8.4V и Gryphon Extreme-Heli DC-DC
