Тема: TG7000 GYRO w/DS0606 SERVO анонс гирика от ТТ  (Прочитано 1631 раз)
« : 08 Октябрь, 2008, 06:29:25 am »
тех характеристики
    Use of the latest SMM (Silicon Micro Machine) sensor eliminates the need for rudder trim changes in flight and provides unmatched performance. It is perfect for electric or nitro powered R/C helicopter.
For beginner, it will greatly reduce the learning process; for experts, it will provide the performance you require. Included with the TG7000 gyro is a Coreless DS0606 high-speed servo. Transit time at 6V is (sec/60°) is .05. Servo case design incorporates a heat sink to ensure solid performance in the most demanding environments.
Features
1)Heading lock mode and normal mode
2) SMM gyro sensor
3) Remote-controlled gain
4) Analog/digital servo compatible
5) Suitable for 760/1520?s digital rudder servo
6) Separated end point adjustment for left and right servo traveling limit
7) Simple wire connection for easy installation
8) Small and light weight
Content
1) TG-7000 Gyro ? 1
2) Mini plastic screwdriver?for adjustment? ? 1
3) Double-sided foam ? 3
4) Metal plate ? 1
5) DS0606 Digital Servo x 1
6) Servo Horn x 2
7) Grommets and mounting hardware set x 1
8) Instruction Manual x 2
Other File Download
Instruction Manual
Parts Catalog
Stock code 8033 Public of Stock web
