Тема: БП от REVOLECTRIX  (Прочитано 4423 раз)
Оффлайн crv
    • Евгений
    • Артемов
« : 05 Март, 2014, 10:33:18 am »
Кто нибудь юзал такой, стоит ли брать?
http://www.store.revolectrix.com/24-VDC-55A-1320W-Power-Station?ext=F
« Ответ #1 : 05 Март, 2014, 10:50:07 am »
А он точно 220в? В пиндосии это редкость.
« Ответ #2 : 05 Март, 2014, 10:52:10 am »
На кой он тебе? возьми вот этот, тем более что их теперь делают 100-240 вольт
http://www.flying-hobby.com/images/large/SK-200015-02/SK-200015-02_00.jpg
    Charger
    Power Supply
    eFuel 50A 1200W POWER SUPPLY (US Plug 100-240V)
    Previous
    Next
With 1200W outputs, adjustable output voltage from 15-30V and active PFC, it is the most advanced power supply you will find anywhere.
1200W of output is ideal for a variety of high powered chargers, and three outputs allow you to simultaneously operate multiple chargers or
other devices.
      An input voltage range of 100-240V makes it ready for worldwide compatibility with no setting required,
and the DC output voltage is flexible: simply turn the dial to adjust the voltage to suit your setup-digital readouts give you an instant look
at your output voltage and current.
      Active power factor correction and a compact frame make this a great power supply to take to the field and use with a generator.
Voltage…………………………………………………………………………………………………100-240V AC
Input AC Frequency…………………………………………………………………………………………50-60Hz
Output Voltage……………………………………………………………………………………15-30V DC±0.5V
Output Current………………………………………………………………………………………………50A±1A
Current Overload Protection…………………………………………………………………………? 51A 500MS
Input Fuse…………………………………………………………………………………………… 20A Fuse
LCD Display………………………………………………………………………………Voltage Precision ±0.3V
Current Precision ±0.5A
Output Voltage Ripple………………………………………………………………………………………< 300mV
Power Efficiency………………………………………………………………………………………………89%
Power Factor……………………………………………………………………………………………………> 0.98
Over Temperature Protection………………………………………………………………………………<65?
Cooling Method…………………………………………………………………………………………Cooling Fan
Operating Temperature………………………………………………………………………………………0-40?
Operating Humidity……………………………………………………………………………………………0-90%
Dimensions (L*W*H)……………………………………………………………………………305x170x85mm
Net weight………………………………………………………………………………………………………3.08kg
Specifications are typical; individual units might vary. Specifications are subject to change and improvement without notice.
Notes : US Plug
1200W Power Supply Manual.pdf
Comments
There are no comments posted yet. Be the first one!
Оффлайн crv
    • Евгений
    • Артемов
« Ответ #3 : 05 Март, 2014, 11:09:49 am »
Этот тоже рассматриваю, но на Револектрикс сейчас скидки.
Оффлайн crv
    • Евгений
    • Артемов
« Ответ #4 : 05 Март, 2014, 11:11:31 am »
А он точно 220в?
Вопрос поставил меня в тупик.
Оффлайн beatl
    • Жуков
« Ответ #6 : 05 Март, 2014, 13:59:43 pm »
Качество изготовления оставляет желать лучшего. Но за эту цену можно стерпеть кривую пайку и царапанный корпус....
Оффлайн crv
    • Евгений
    • Артемов
« Ответ #7 : 05 Март, 2014, 15:51:10 pm »
Да хрен с ним с корпусом, с внутренностями всё в порядке, характеристикам своим соответсвует или лучше взять SKY RC?
Оффлайн beatl
    • Жуков
« Ответ #8 : 05 Март, 2014, 16:26:54 pm »
Два согласованных серверных БП Dell. Два слота подключения к сети. Ручная пайка...
Халява глаза застит? )))))
Оффлайн crv
    • Евгений
    • Артемов
« Ответ #9 : 05 Март, 2014, 17:07:55 pm »
Ну не такая уж халява. Разница с E FUEL всего 20$. Просто хотелось понять если ли смысл переплачивать.
Оффлайн ek7pp
  • SAB Kraken, Futaba Т18MZ WC
    • karen.gharibyan
    • Karen
    • Gharibyan
« Ответ #10 : 05 Март, 2014, 17:29:23 pm »
На счет серверных блоков питания, я обратилься в местное представительство НР на счет наличии у них вышедших из строя серверных блоков питания, они любезно и бесплатно дали мне две одинаковые, у которых есть выход 12В 35А, сам отремонтировал, что мне обошлось в районе 20$, и после небольшой переделки, получилось 24В 35А, думаю неплохо. :)
Sent from my iPhone using Tapatalk
« Последнее редактирование: 05 Март, 2014, 17:34:27 pm от ek7pp »
« Ответ #11 : 05 Март, 2014, 23:48:35 pm »
сам отремонтировал
А что именно? Что-то очевидное или глубокое понимание устройства БП?
Оффлайн ek7pp
    • karen.gharibyan
    • Karen
    • Gharibyan
« Ответ #12 : 06 Март, 2014, 07:57:07 am »
Если в электронике разбираетесь, не будет проблем, в моем случае не такие уж глубокие были проблемы, там пара транзисторов и диодов
Оффлайн crv
    • Евгений
    • Артемов
« Ответ #13 : 06 Март, 2014, 09:30:04 am »
Решил брать все таки EFUEL. Вопрос к знатокам SKYRC, в чём принципиальное отличие старой версии http://imtoy.ru/cgi-bin/good.pl?good=5648 от новой http://www.rcteam.ru/skyrc/sk-200015.html?
« Ответ #14 : 06 Март, 2014, 09:52:38 am »
Старая была 2-х версий, на 220в и 110. Эта универсальная, т.е. есть шанс что при больших падениях в сети будет работать.
