Тема: KOSMIK Firmware Update  (Прочитано 9693 раз)
« : 20 Ноябрь, 2013, 23:26:10 pm »
Вышла новая прошивка для Космика 4.2 и для диска 1.9
Лежит тут: http://www.kontronik.com/index.php?option=com_moofaq&view=category&id=81&Itemid=193&lang=en
Но контрон не был бы контроном, если бы не организовывал
удаление гландов через жопу  :)
Письмо от Контрона № 1:
Dear Customers,
Recently, we have determined that there is a possibility of a KOSMIK ESC
being rendered non-functional after a firmware update. Although this occurrence is rare,
we would like to request that you temporarily suspend any firmware updates to your KOSMIK.
We will be working to resolve this problem immediately and will inform you once a solution is available.
Please understand, the failure in question only occurs during a firmware update.
Any KOSMIK that is functional may continue to be used with full confidence.
We thank you for your understanding and continued support of our products.
KONTRONIK
Краткая суть: во время обновления можно зависнуть ,
поэтому лучше не обновляйтесь  :D
Письмо от Контрона № 2 :
Было отправлено всем дилерам, мне ХелиДирект по дружбе прислал.
Dear Business Partners,
On November 13, 2013 an update advisory was issued concerning the KOSMIK
update process. At this time we are happy to announce that we have solved the
intermittent error during the update process.
Please instruct all customers to update their PROGDISC to the newest firmware v1.9.
This new PROGDISC firmware will insure the successful update of the KOSMIK to v4.2.
Instructions for the update will be on our homepage, but you may also send
the PROGDISC or KOSMIK to our service center for the update.
Thank you for you understanding and continued support of our products.
Sincerely,
KONTRONIK
Краткая суть:
не бздо! Новая прошивка не виснет! Прошивайте клиентов смело!
« Ответ #1 : 20 Ноябрь, 2013, 23:36:12 pm »
Игорь, а там кроме возможого зависания во время прошивки еще что нибудь изменили?  ;)
« Ответ #2 : 21 Март, 2015, 18:50:21 pm »
Обновить прошивку на Космике это просто!
(обновлял сегодня до последней - 4.5)
Порядок действий (последовательность важна)
Никакой отсебятины, все по инструкции:
----------I------------------------
Обновляем прошивку PROGDISC до последней:
1) скачиваем обновление отсюда:
2) запускаем программу
3) подключаем PROGDISC к компьютеру с Windows по USB
4) удерживаем кнопку несколько секунд для перехода в режим обновления (светодиоды замигают поочередно) и программа увидит текущую и доступную версию ПО (сегодня это 1.9)
5) нажимаем кнопку обновить
6) после окончания процесса обновления программа сообщит об удачном обновлении ПО
-----------II------------------------
Обновление ПО регулятора KOSMIK ( сегодня это 4.5):
1) скачиваем файл с обновлением отсюда:
2) подключаем PROGDISC к регулятору (разъем MASTER)
3) подключаем питание к регулятору 20-59V
4) нажимаем кнопку на PROGDISC и убеждаемся, что регулятор доступен для PROGDISC
5) подключаем PROGDISC к компьютеру с Windows по USB
6) Закрываем все другие программы.
7) Запускаем программу обновления
 - в левом верхнем углу окна наблюдаем, что программа видит устройства и отображены версии
 - нажимаем кнопку обновить
 - ждем окончания процесса обновления ( несколько минут )
 - ничего не закрываем и не трогаем, даже если увидите сообщения глупых окон типа "программа не отвечает"
 - после окончания процесса обновления программа сообщит об удачном обновлении ПО
8) Отключаем питание регулятора, отключаем PROGDISC
9) Программируем регулятор с нуля (возвращаем все так, как было):
- выполняем сброс Mode 1
- устанавливаем Mode 4
- c помощью PROGDISC выставляем необходимые параметры (напряжение БЕК, режим гувернера, режим отсечки, возвращаем гейны как были ( по умолчанию 4, а у некоторых 9-11))
Для упрощения задачи 9) и наглядности есть фирменная утилита  K-KONFIG V 1.1.0, работающая через PROGDISC по USB.
Идем летать! Первый полет плавно, с увеличением нагрузки (обучаем адаптивное ПО регулятора)
Удачи, парни!
Оффлайн divrc
    • Дрюма
« Ответ #3 : 26 Июнь, 2018, 12:33:35 pm »
Вышел новый софт для Kosmik и Jave Pro, 4.12 и 1.12 соответственно.
Обновлена версия протокола для считывания данных из устройств.
https://www.kontronik.com/fileadmin/kontronik-sobek/Public/Content/Images/Content/Downloads/Software/Kontronik_TelMe_V4.12_1.12_EN.pdf
Оффлайн nik1
    • Гончаров
« Ответ #5 : 26 Июнь, 2018, 18:34:51 pm »
Вопрос конечно интерсный, надо ли обновляться или оно того не стоит :)
3Daemon
« Ответ #6 : 26 Июнь, 2018, 20:04:27 pm »
Вообще для Jive Pro последняя версия FW 1.13 а для Kosmik 4.13.
Смотрю я на эту страничку (https://www.kontronik.com/en/downloads.html) - это пипец товарищи! КАК версия 1.13 может быть свежее версии 1.6 ????
Но это факт! 1.13 - 10.04.2018, a 1.6 - 30.07.2015
Они там ибанулись или я чего не понимаю?
Оффлайн morro_lucky
    • morro_lucky
    • Юрий
    • Губанов
« Ответ #7 : 26 Июнь, 2018, 20:08:09 pm »
А что не так?
Вот если бы 1.1.3 против 1.6
А так : 13>6
3Daemon
« Ответ #8 : 26 Июнь, 2018, 20:14:49 pm »
Чё? Я с софтой и нумерациями версий не один десяток лет работаю :)
И как бы знаю что версия 1.6 должна быть свежее версии 1.13, ибо 1.6 > 1.13 !
Но у Контрона похоже какая-то странная логика... Там блин ещё и 1.19 есть  | 8-(
Оффлайн divrc
    • Дрюма
« Ответ #9 : 26 Июнь, 2018, 20:43:34 pm »
Обновил Jave Pro. На Футабе те же 8 параметров.
« Ответ #10 : 26 Июнь, 2018, 23:49:29 pm »
1.13 это не одна цифра, а две разные, но через точку :)
Мажорный апдейт 1, и минорный апдейт 13.
Потому и сравниваем 13 и 6
Отправлено с моего SM-G950F через Tapatalk
« Ответ #11 : 27 Июнь, 2018, 00:20:48 am »
Ты думаешь Игорь точку в номере версии как разделитель десятичной части воспринимает?  :-\
Тогда действительно 1.6 > 1.13 :)
3Daemon
« Ответ #12 : 27 Июнь, 2018, 10:03:55 am »
А на какую-таки версию? ;)
Реально же непонятка с версиями.
Я вот с софтой с 90-го года прошлого века работаю, а последние 16 лет в software development company, причём в Германии. Цифирки немцы произносят конечно наоборот (пресловутые "vier und zwanzig" = "четыре и двадцать" =24), но пишут же как все!
Во всём мире нумерация версий стандартная:
* девелопер начал разработку - версия 0.01, чего-то накодил - 0.05, потом 0.1, потом 0.2, 0.23 и так далее
* получилась какая-то тестовая версия для внутреннего употребления - ну скажем 0.53, отдали в тестинг
* тестеры нашли баги, пофиксил, добавил фичу - 0.6 получилось например
* зарелизили, версия 1.0
* тут же нашли баги, пофиксили, получилась версия 1.05 или там 1.1 если какую-то фичу дописали
* ну а дальше - минорные апдейты 1.2, 1.25, 1.28
* если чего помажористей добавили - ну будет 1.3 или там 1.35
* если новая фича, мажорный апдейт - ну будет 2.0 или 2.1 или 2.11
Вот как-то так у всех. А у Контроника я не понимаю логики. Если 1.13 последняя - что тогда 1.6 или 1.19? Как так?
Оффлайн divrc
    • Дрюма
« Ответ #13 : 27 Июнь, 2018, 10:43:53 am »
1.12, но что изменилось по сравнению с предыдущими версиями не ясно.
1.13, как я понимаю, это исправление ошибок в работе - TelMe JETI и Graupner.
На немецких форумах
https://www.rc-heli.de/board/showthread.php?s=89cc5b5052dbbd0dbc3f718f3f9e83d3&t=263359
http://j-log.eu/forum/viewtopic.php?f=24&t=1037&view=next
версия 1.12 обсуждалась, но я в немецком не силен.
Единственное, что я понял, что при использовании J-log в связке с Футабой вместо 8 параметров доступно 12, но в нашем случае, это все - до лампочки.
или 1.19?
1.19 - не нашел.
« Последнее редактирование: 27 Июнь, 2018, 11:07:02 am от divrc »
