Тема: Motor Bearing Lubrication Kit масло для подшипников  (Прочитано 2788 раз)
« : 15 Август, 2008, 06:26:57 am »
На Скорпионовских моторах   горят подшипники, вот чуваки советуют воспользоваться этим чудо-маслом для смазки этих самых подшипников.
To keep your brushless motor operating at maximum performance, it is important that the bearings in your motor be properly maintained. This is especially true of helicopter motors that often spin in excess of 45,000 RPM. In an average flight, the motor in a 450 size helicopter spins around almost a quarter million times! Without proper lubrication, the balls in the bearings can wear out quickly, leading to premature failure.
We have put together a motor bearing lubrication kit to help extend the life of the bearings in your Scorpion brushless motor. This kit contains a 25cc bottle of bearing lubricant and two needle point applicator nozzles. One nozzle is 1" long, and will work with the 22mm and 30mm motors, and the other nozzle is 1.5" long to use with 40mm and larger motors.
The oil included in the kit is a special product that actually bonds to the metal parts, and resists being thrown out by the high speed and centrifugal forces inside the bearings. A small drop placed on each bearing about once every 10 flights is enough to maintain proper lubrication to insure the longest possible life for your motor bearings. Click here to check out the Motor Bearing Lubrication Kit on our site.
« Последнее редактирование: 05 Октябрь, 2008, 05:29:09 am от SkyForever »
Оффлайн Andrei_S
« Ответ #1 : 15 Август, 2008, 08:46:46 am »
отмазались собаки.
нет чтобы нормальные подшипники ставить так они свою смазку будут впаривать :)
