Тема: Spartan- Flash-Link  (Прочитано 2342 раз)
« : 11 Июль, 2008, 07:43:08 am »
Новинка от  Spartan-новый шнурок :D
Many Spartan products benefit from computer connectivity capabilities for the purpose of modifying their configuration parameters or updating their firmware when improvements are made. To take advantage of these features an optional Flash-Link or Blue-Link interface module is required offering USB or Bluetooth connectivity respectively. In addition to computer connectivity the Bluetooth option can be used with certain PDAs and mobile phones providing a convenient way for editing configuration parameters at the field. Not all of our products support these options; specific information can be found on each product’s own web page.
Flash-Link Requirements
USB1.x or USB2.0 enabled PC running Windows XP or Vista operating system.
Installation
The Flash-Link is an intelligent cable incorporating a USB controller inside the USB plug housing and therefore it requires operating system drivers to function. For a smooth installation endure that the drivers are already installed before plugging the cable to the computer for the first time.
Any computer software related to the product that you wish to interface to can be downloaded from the the particular product's web page.
Drivers for old type cables
If your Flash-Link cable is not identical to the one pictured on this page you will need to use the drivers below. Observe the colour of the servo type plug fitted to your cable to choose the appropriate driver below.
• Flash-Link (blue plug) Driver v2.0.2.1 for Win2K/XP/2003 (XP Logo Certified)
• Flash-Link (blue plug) Driver v3.2.0.0 for Windows Vista 32bit and 64bit
• Flash-Link (black plug) Driver. Only use if Windows can't automatically locate it.
« Последнее редактирование: 04 Октябрь, 2008, 22:22:13 pm от SkyForever »
« Ответ #1 : 23 Июль, 2008, 20:58:37 pm »
Внутри
« Последнее редактирование: 04 Октябрь, 2008, 22:22:32 pm от SkyForever »
« Ответ #2 : 23 Июль, 2008, 23:36:56 pm »
Ах ... какие же люди ... падкие до халявных денег!  >:D
Простейший и трёх-копеечный мост USB-UART засунутый в "круто фирменный" корпус - продают за такое баблосо!  :o
А если скажем взять такой же переходник (на ФТДИШном чипе), а в спартановских дровах - заменить ГУИД на тот, что у переходника?
Я когдато так делал с другими устройствами (по такой схеме) - всё пучком работало!  :D
Оффлайн rpilot
    • RC-COMBAT
« Ответ #3 : 24 Июль, 2008, 00:33:20 am »
Я думаю что ничего менять не надо. Скорее всего он автоматом проверяет все последовательные порты и ищет нужный ответ от свободного порта. Я подобный использую для настройки ATG . Как правило выходного напряжения 3V достаточно для работы с обычной логикой без дополнительного согласования уровней.
Надо бы унифицировать расположение проводов для подключения к устройствам.
