Тема: E-STATION BC6 Balance Charger 1-6 Lipo Cells  (Прочитано 4845 раз)
« : 04 Июнь, 2008, 09:13:32 am »
За третье место получил вот такой зарядник.
Понравилось- качество изготовления, возможность заряжать любые батареи, работает и от сети и от источника питания 12в и встроенный балансир до 6s батарей, и всё это в достаточно компактном металлическом корпусе-удобно и практично одним словом.
Можно подключить к компу для контроля батарей и температурный сенсор.
SpecificationOperating voltageDC 11~18 voltsAC 100~240V, 50/60Hz
Charge/discharge powermax. 50/5 WattsNiCd/MH
1~15 cells
LiIo/LiPo/LiFe
1~6 series
Pb 2~20V
Charge current
0.1 to 5.0A
Discharg current
0.1 to 1.0A
No. of cycle
1 to 5 times
Battery data memory
up to 5 data
Weight 960g
Dimension 160x120x40 mm
User's setting-up parameters
Lithium battery voltage type
LiIo:3.6V, LiPo:3.7V, LiFe:3.3V
NiCd Delta-peak voltage sensitivity 1 to 20mV
NiMH Delta-peak voltage sensitivity 1 to 20mV
Battery temperature cut-off
20 to 80C or OFF
Waste time between charge/discharge
1 to 60 min.
Integral timer limit for safety 10 to 720 min.or OFF
Maximum charging capacity limit for safety 10 to 9990mAh or OFF
Key beep and buzzer sound ON/OFF
Input DC power low alert 10 to 11V
Note: With 6S 22.2V batteries, max amperage when charging is 2.5A due to wattage of charger.
Optimized operating software
When charging or discharging, BC6 has an 'AUTO' function that sets the feeding current or the cell count of Lithium battery automatically. Especially for Lithium batteries, it can prevent the over-charging can lead to an explosion by users fault. Every program in the unit is controlled with mutual links and communication for every possible error so it introduces a maximum safety. These can be set at users option.
- Dual input power
BC6 employs the circuit that can be operated with the input power of AC(Alternating Current) or DC(Direct Current). For AC input, it contains a AC-DC switching power supplier which has 5A of power capacity and maximum output power of 50Watts for charging. As a result it can charge up to 15 cells of NiCd/NiMH and 6 series of Lithium batteries with maximum current of 5.0A.
- Individual voltage balancer for Lithium batteries inside
BC6 has an individual-cell-voltage balancer inside. So it does not need any balancer separately when charging Lithium batteries (LiIo/LiPo/LiFe) for cell voltage balancing.
When the 'Balance charge' mode being performed, the balancing adapter should be connected to the balancing tab of battery pack, as well as the charger's charging lead should be connected to the output of battery pack.
And also, please pay attention to the polarity of the battery pack's output which goes to the charger's output. If it is reversed, the short-circuit can be happened on the battery pack.
Balance individual cells on discharge
BC6 also can monitor and balance individual cells of the Lithium battery pack during the discharge process. If the voltage of any one cell varies abnormally, the process will be stopped with the error message.
Accept various types of Lithium battery
BC6 can accept three types of Lithium batteries - LiIo, LiPo and LiFe. They have different characteristics by their chemistry. You can select any one of them that you are going to process before the job.
- Lithium battery 'Fast' and 'Storage' mode
You can charge Lithium battery for special purposes. 'Fast' charge reduces the charging time of Lithium battery and 'Storage mode controls the final voltage of the battery to be suit for long time storage.
- Data store/load
For users convenience it can store maximum 5 data of different batteries. You can establish the data contains program setting of the battery to charge or discharge continually. These data can be called out at any time you need and the process can be executed without program setting.
- Cyclic charging/discharging
Perform 1 to 5 cycles of charge>discharge or discharge>charge continually for battery refreshing and balancing.
- PC based analysis using USB communication
For technical expert, BC6 offers PC based program can analysis the characteristic of the battery by USB port. It shows a graph of voltage, current, capacity and temperature curves. It also shows the individual voltage of each cell in the Lithium battery pack.
Robust outer aluminum case
High-quality aluminum case is durable and very efficient to cool out the internal heat
Accessories
EAC110
Temperature sensor cable
 EAC117
4mm gold banana plug with silicon cable and alligator clips
Standard
EAC120
8-pin cable for individual cell connector
EAC200
Charge graph program kit (CD + USB cable)
« Последнее редактирование: 05 Октябрь, 2008, 03:41:04 am от SkyForever »
Оффлайн Serj
  • э...
« Ответ #1 : 04 Июнь, 2008, 14:14:40 pm »
Тим,  а ты заряжать им уже пробовал полимеры? после окончания зарядки на банках сколько вольт? 4.2 или меньше? :-\
« Ответ #2 : 04 Июнь, 2008, 16:29:04 pm »
Пока не пробовал, а даже если будет 4,17 этого достаточно, главное чтобы в банках разбаланс не более 0,02 был.
« Ответ #3 : 13 Июль, 2008, 09:43:40 am »
Понравился режим Balance-после зарядки все банки заряжены до 4,2в
Оффлайн Sadykov Daniyar
    • Данияр
    • Садыков
« Ответ #4 : 13 Июль, 2008, 20:04:54 pm »
Привет!
Я заказал себе 301ДХ тоже бантамовский.....
Говорят Бантам хорошие зарядки....
« Ответ #5 : 13 Июль, 2008, 20:10:45 pm »
Вот таким образом решается вопрос о 220в, берётся блок питания и засовывается во внутрь.
« Ответ #6 : 13 Июль, 2008, 20:17:35 pm »
Первое наше знакомство немного не удалось-не сильно вникая в мануал вставили в балансирный разъём батарею-запахло в воздухе горелым и повалил дым-жаль подумали мы-новая зарядка и сгорела.
Пришлось вскрыть-отгорела дорожка- всего то, подпаяли провод и о чудо зарядник снова заработал :D, а всего то нужно было взглянуть в книжку с картинками и увидеть, что батарею нужно втыкать смещая на один контакт, на него просто одеть кембрик-ВНИМНИЕ лучше купить Бантамовский переходник зарядка -батарея дабы избежать конфликта с зарядником-
А свою работу зарядка выполняет отлично.
    • Данияр
    • Садыков
« Ответ #7 : 13 Июль, 2008, 20:37:52 pm »
ну блин бантамовцы дают.....
взяли и запихнули просто блок питания в зарядку.... =)
я буду использовать блок от компа...
Оффлайн halfer
« Ответ #8 : 26 Апрель, 2011, 08:52:07 am »
а есть у кого программа "e-STATION Program"?.
в описании моего зарядника "HobbyKing ECO6-10 200W 10A 6S" написанно, что такая прога подходит.
Kyosho Inferno US ST sports 27,145 АМ канал №4 ГАЗЕЛЬизм не болезнь, это образ жизни. (с) Я . . .
kostua_d
« Ответ #9 : 26 Апрель, 2011, 13:12:19 pm »
а есть у кого программа "e-STATION Program"?...
На офсайте есть.
