Тема: SPEKTRUM DX8 - Вышла новая прошивка 2.0  (Прочитано 15869 раз)
Оффлайн rpilot
    • RC-COMBAT
« : 09 Февраль, 2011, 19:01:58 pm »
Version 2.00
Software Upgrades
• DSMX is enabled.
• DSMX/DSM2 bind mode is now shown on the main screen immediately to the
right of the Spektrum logo.
• DSMX/DSM2 mode selectable on the Frame Rate screen. Note that a DSMX
receiver is necessary for DSMX operation.
• Added support for new Telemetry sensors Airspeed, Altitude, and PowerBox.
• Receiver Voltage is now shown on the Min/Max screen.
• Telemetry menu is now a scrolling list, to improve ease of use as the number of
possible sensors increases.
• When setting the Flight Pack Voltage alarms, you can easily set the alarm points
based upon LiPo cell count, then tweak them to your preference.
• The low-level SD interface is updated to improve compatibility with PC’s.
• Mix and Gear switches can now be used in mixing functions to have the active
position either 0 or 1. These are named Mix-0/Mix-1 and Gear-0/Gear-1. The “1”
option is the same as the old Mix or Gear option, as the mix function was
previously active in position 1.
• The Timer Setup screen now hides information which is not related to the
selected timer mode.
• In Elevon wing types, the Flap System is enabled, providing the flap function on
Aux 1 and enabling proper elevator compensation. In this mode, the Aux1
channel would typically be used either as a drag brake or a spoiler.
• The Serial Number screen now includes an EXPORT function to make it simpler
to enter the serial number when registering a new radio.
Software Corrections
• Mix Switch – The Mix Switch was sometimes treated as a 3-position switch.
• Mode-Change Recalibration – When changing between Mode 1 and Mode 2,
the throttle and elevator sticks were calibrated to different tolerances than during
factory calibration.
• Telemetry Alarming – Corrected problem with multiple alarms on main voltage
sensor inter-acting with one another.
« Последнее редактирование: 09 Февраль, 2011, 19:03:47 pm от roytman »
Оффлайн SlavikR
« Ответ #1 : 12 Февраль, 2011, 09:48:51 am »
Интересное видео , даже если нет английского , непроблема с 3.42мин думаю можно догадатся о чём идёт речь и Вы будете понимать что такое DSMX .
Оффлайн SHYrix
« Ответ #2 : 10 Апрель, 2011, 19:52:46 pm »
Купил себе такую аппаратуру, в новых прошивка стоит уже 2.01 и еще вопрасик  не подскажите где взять к ней шнур для подключения к симулятору? Спасибо.
« Ответ #3 : 05 Май, 2011, 22:48:23 pm »
Подскажите, можно ли к аппаратуре Spektrum DX8 прибиндить попроще и подешевле приемники например от DX6???
SeverTV
« Ответ #4 : 05 Май, 2011, 22:55:35 pm »
Наши Товарищи говорят Да.Спрашивал как то.
« Ответ #5 : 05 Май, 2011, 23:00:37 pm »
Андрей - ты теперь в каждой теме спрашивать будешь?
Какая разница сколько каналов? 6 или 7 или 8 или 9 ?
Старые (относительно) приёмники не будут работать в новомодной модуляции вот и всё. А в DSM2 - работать обязаны.
Не возьми с дуру совсем старый шестиканальник, который под DSM (без циферки 2).
"Оранжи" - работают вроде, но сам понимаешь - тут гарантий нет никаких  :D
« Ответ #6 : 05 Май, 2011, 23:42:23 pm »
Понял. Желательно брать DSMX. Но на 7 моделей 7 приемышей по 115 долларов - накладно. Вот и спрашиваю можно ли взять приемники - AR6110 DSM2 например или AR6110e DSM2. С оранжами тоже понял. Смысла нет брать сомнительные по надежности оранжи под надежную аппаратуру.
« Ответ #7 : 05 Май, 2011, 23:57:10 pm »
Так в чём проблема с 6-ти каналками? Бери конечно, если на электричку и лишние каналы не нужны.
« Ответ #8 : 09 Август, 2011, 22:37:22 pm »
Итак вышла БЕТА прошивка версии 2,03
Из нововведений по моему мнению самых интересных, отмечу два - расширение экрана телеметрии и поддержки различных дополнительных датчиков (альтиметр, датчик скорости и т.д.) и второе - полная калибровка стиков и даже крутилки  ;) Ну там еще некоторую косметику на экране обещают, новые типы крыла, и кое какую косметику функционала.
Английский вариант в приложении.
Оффлайн Ph@ntom
  • Дмитрий Лаптев
« Ответ #9 : 09 Август, 2011, 22:51:48 pm »
Вот нафига нужна поддержа датчиков если самих датчиков нет :-\ да и впредпоследней версии прошивки эта поддержка есть
Gaui X5
« Ответ #10 : 09 Август, 2011, 23:03:10 pm »
Дык в стоке уже  ;)
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMA9574
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SPMA9575
Ценник только не гуманный, но это дело времени, не будут брать - отключим газ.
Оффлайн Ph@ntom
  • Дмитрий Лаптев
« Ответ #11 : 09 Август, 2011, 23:06:44 pm »
 :o спс, а на офф сайте их даже в планах невидно :) убежал заказывать O0
Gaui X5
Оффлайн val-ksd
« Ответ #12 : 09 Август, 2011, 23:07:24 pm »
Сори за ОФ. Про оранж для спектрума не скажу, использую два под футабу на 450х, проблем не было.
Сергей.
« Ответ #13 : 10 Август, 2011, 08:00:22 am »
любопытно посмотреть на человека, который пользует телеметрию на 3Д вертолете.
ЗЫ: $50 баксов за датчики на самолет за $2000 - вполне реально. Другой вопрос - кто на спектруме полетит на такой модели ;) Тем не менее.
baratynsky
« Ответ #14 : 10 Август, 2011, 10:57:22 am »
Илюха. Я пользую телеметрию на 3Д-вертолете. Правда только стандартную - термодатчик, отслеживание потери пакетов и бортовое питание приемника
