Тема: Тахометр, ваттметр, сервотестер все в одном флаконе  (Прочитано 4249 раз)
« : 25 Декабрь, 2007, 10:44:15 am »
Во какая игруха за 144 у.е, жаль тахометр только до 3000.
 Precision pulse generator to test servos
You can test any brands of servo by movement, deflections, neutral point and band width.
 It does not need battery to operate servo.
It shows the electric current to operate the servo simultaneously. This feature is very helpful to choose an appropriate RX battery for your model by adding all current load of servos.
Watt meter up to 100A
You can estabolish your power plant with a right propeller for the best current.
 Watt meter can be operated with tachometer
Automatic voltage/amp calibration. No need to calibrate the voltage of source.
Additional power supply is not needed even the input power source is less than 4.5V.
  Rotor blade tachometer
  Precision tachometer up to 3000RPM. Rotating-drum type slit syncronize system.
Up to 10 incidental RPM can be stored to the memory.
Temperature sensor
 Solid-state temperature sensor by contacting the material being checked.
 RX battery checker/discharger
You can check your RX battery with a certain current load accurately.
NiCd 4.8/6.0/9.6V and Lithium 7.4V with 100 to 1000mAh current load
When being checked, the present voltage and the residue of capacity are displayed
NiCd batteries can be discharged to 0.9V/cell.
Back-light LCD screen
 You can adjust the brightness of LCD display
 Automatic power off and back-light off
To prevent from wasting the energy, the power will go off when there is no action for 10 minutes.
 The back-light will go off  in 1 minutes if you do nothing with the unit.
Robust outer aluminum case
High-quality aluminum case is durable and very efficient to cool out the internal heat
Additional Information
Helimaster Manual
Оффлайн Galantniy
« Ответ #1 : 31 Май, 2014, 12:01:42 pm »
А где купить подобный или уже появились более новые модели?
Оффлайн AlexandrT
« Ответ #2 : 31 Май, 2014, 19:12:51 pm »
Оффлайн Galantniy
« Ответ #3 : 31 Май, 2014, 21:00:30 pm »
Вот например: http://www.buddyrc.com/skyrc-7-in-1-imeter.html
Я так понимаю, что он не оптический?
Оффлайн AlexandrT
« Ответ #4 : 01 Июнь, 2014, 05:29:24 am »
Он оптический.
В корпусе датчик.
http://www.hobbyhot.com/usermanual/SKYRC-i-Meter-Battery-Watt-Servo-Temp-Optical-7in1-RC-Multimeter-BK208.pdf
Оффлайн Galantniy
« Ответ #5 : 01 Июнь, 2014, 10:13:35 am »
Он оптический.
В корпусе датчик.
Понял, но для вертолета судя по всему в полете не померить им обороты.
