Тема: Product Recall: Spektrum DX6i transmitters with date codes 807E, 808E, 809E, 810  (Прочитано 3878 раз)
« : 23 Март, 2009, 14:37:27 pm »
Спектрум ещё в феврале сообщил о отзыве DX6i со следующими датами (кодами) выпуска: 807E, 808E, 809E, 810E, 811E, 812E, and 901E .
Проблема связана с резисторами стиков и была известна раньше. Но они решили отозвать указанные передатчики для "осмотра".
If your DX6i has one of these date codes:
Stop using your transmitter.
Click here for return form with specific country instructions.
If you have any questions, you can call us at 877-504-0233
Due to the possibility of replacement, please document for your own records any model programs prior to shipping.
Only the transmitter needs to be returned. Please remove any batteries prior to shipping.
Horizon will pay for all ground shipping within the United States and Canada.
Each transmitter will be inspected for the issue, repaired or replaced if necessary, and returned as soon as possible. We will work as quickly as possible, but we ask for your patience.
Inspected, repaired, or replaced DX6i transmitters will have date codes ending in "CM", "LH", "HA", or "X". No further action will be needed on transmitters with those suffixes. If your transmitter does not have a date code, it is not affected by this recall.
Consumers outside the US and Canada should contact their local retailer or distributor.
International distributors may be found here.
You may also e-mail the Horizon Hobby Product Support team and please put "DX6i Transmitter Recall" in the subject line and include your shipping address, daytime phone number, and the date code from your DX6i. Click here to email product support
Оффлайн AlekseyM
« Ответ #1 : 24 Март, 2009, 10:09:26 am »
про 7 как я понимаю пока тишина? и это с одной стороны радует, с другой ждём ремкомплектов под 6-7.
« Ответ #2 : 24 Март, 2009, 11:51:18 am »
А вот интересно, резюки у 6i и 7 - одинаковые? Или всё же нет? Да, и ещё есть 5-ка ..., а что в ней стоит? В качестве "ЗИПа"  ;) не сгодиться?
« Ответ #3 : 24 Март, 2009, 12:13:31 pm »
Резюки в 6 и 7 разные
