Тема: HiModel Balancer Series 40A / 55A Brushless ESC Type BALANCER-40A  (Прочитано 3175 раз)
Оффлайн planeant
« : 26 Январь, 2009, 06:12:54 am »
Прокоментируйте пожалиста, чегото я не понял зачем ему балансировочные разеъмы
THIS IS THE HIMODEL NEW BALANCER SERIES BRUSHLESS SPEED CONTROLER:
?Great innovation: First on earth with Lithium battery Balance Discharge Monitoring and Protecting Design, real time monitoring the discharge voltage of each lithium (Li-ion/Li-poly) cell in a battery pack. No longer worry about over discharge problem, your lithium battery pack will have much longer life. (Remark: This function is ONLY available for “BALANCER” series ESC)
?Startup music playing functionality. (With a program card, you can select one of 15 songs or disable the music playing function)
?Extreme low resistance, super current endurance.
?Full protection features: Low-voltage cutoff protection / over-heat protection / throttle signal lost protection
?3 startup modes: Normal / Soft / Super-Soft startup, can be used for both fixed-wing aircraft or helicopter models
?Throttle range can be configured, fully compatible with all market available transmitters.
?Smooth and accurate speed control, excellent throttle linearity.
?Microprocessor uses separate voltage regulator IC, with good anti-jamming capability.
?Supported highest motor speed: 210000 RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles).
?Own complete intellectual property rights, software can be upgraded for our customers.
?Programming CARD in a very small size can be purchased additionally for easily programming the ESC on field.
    Specifications:
    Model:BALANCER-40A
Input Voltage Range: 2-5 Cell Lipoly or li-ion ; 5-15 Cell NiMh/NiCd
Current:40 Acontinue 55 A burst (10s)
BEC Mode: Switch Mode
BEC (Output current):5V/3A
Weight:40g
Click here for CE Certificate
All the HiModel electric speed controllers (ESC) are comply with RoHS standard, the certificate is under processing.
    Includes/Requires:
    Includes:
1 x ESC / With balance adaptor #1
1 x English Manual
    Comments:
    Please note that the ESC can handle up to 5S lipos, but when using the balancing discharge plug, it only supports:
a. Adaptor #1 (Align battery connector): 2-4S
b. Adaptor #2( to be pruchased separately):
Thounder power battery connector 2-3S
Polyquest & E-tec 2-4S
HiModel
2006/07/17
[attachthumb=#]
« Ответ #1 : 26 Январь, 2009, 06:42:48 am »
По идее делать не по общей напруге, а по самой слабой банке, дабы продлить им жизнь, а там поди разбери этих кетайцев, мож и баллансир втроили :)
« Ответ #2 : 26 Январь, 2009, 12:58:18 pm »
А что там за дата в низу стоит: 2006/07/17 ?  ::)  Видать, не очень удачно встроили?  :D
Не очень понимаю смысл. Нафига в регуле балансир? Следить за отсечкой побаночно - не более того.
Шунтировать то под нагрузкой банки нельзя (бред полный  ::) ).
Но, если батарея "кривая", то это же её не "вылечит". Всё равно сдохнет. Только полётное время сократится.
Оффлайн Piranha
  • My name is Дима
« Ответ #3 : 26 Январь, 2009, 13:15:32 pm »
Идея в том что регуль разряд в полете побаночно мониторит
Оффлайн planeant
« Ответ #4 : 26 Январь, 2009, 13:24:44 pm »
Это дата выпуска...
Оффлайн planeant
« Ответ #5 : 26 Январь, 2009, 13:25:31 pm »
Вот и пытаюсь выяснить на сколько это полезно, и надо-ли ?
Оффлайн Piranha
  • My name is Дима
« Ответ #6 : 26 Январь, 2009, 13:28:53 pm »
По мне -так чистый маркетинг :)
Оффлайн planeant
« Ответ #7 : 26 Январь, 2009, 13:47:08 pm »
Ну блин, помоему не так все просто. Но спорить не буду.
