Тема: Vortex VX1  (Прочитано 19224 раз)
« Ответ #15 : 11 Июль, 2013, 22:16:45 pm »
« Ответ #16 : 18 Июль, 2013, 13:11:50 pm »
Денис Нижегородцев  сделал полный перевод мануала для Vortex VX1
и выложил его в на RC-design: http://forum.rcdesign.ru/f65/thread268318-3.html#post4344061
Огромное спасибо Денису за кропотливый труд!
« Ответ #17 : 05 Август, 2013, 16:38:49 pm »
Вышло обновление М4  :)
« Ответ #18 : 05 Август, 2013, 16:55:12 pm »
Ну вот, дождались версии V2 !
Изменения внесли весьма существенные.
Все косяки, про которые я писал, в версии V2 исправлены,
если верить описанию:
M4
Severity: Recommended to new and old users.
DataPod: 2v00
Flight Computer: 2v00
Sensor: No change
* Added automatic Pitching Up Compensation for high speed flight. New parameter in
  Rotor menu controls the magnitude of compensation.
* Improved tail acceleration/deceleration/reversal algorithm. The default values for
  tail acceleration and deceleration have also been updated to match the algorithm.
* Improved cyclic acceleration/deceleration algorithm. The default value for Rotor
  Acceleration, Deceleration have also been updated to match the algorithm.
* Improved tail stops (also see notes about trim flight). The default values for the
  tail stop gains have also been updated.
* Trim flight also gathers data about tail hover torque to equalise stop behavior. It
  is moved to system menu as its function now spans across both main rotor  and tail.
* Throttle output (SV5) does not get activated until the radio has linked. This allows
  ESCs to enter program/calibration mode when stick is high.
* Failsafe now requires a longer duration of signal loss before it activates.
* Added new receiver type "UDI". The receiver option auto-detects various protocols
  including the upcoming JR XBUS.
* Added 135 degree swashplate and improved the 140 degree.
* New V2 main rotor algorithm provides excellent out of the box performance.
« Ответ #19 : 15 Август, 2013, 10:59:12 am »
Денис Нижегородцев сделал перевод мануала для версии V2:
http://forum.rcdesign.ru/f65/thread268318-3.html#post4408025
« Ответ #20 : 09 Сентябрь, 2013, 01:01:00 am »
Объясните мне, что это за ход конём через жопу сделал Spartan,
выпустив неожиданно на рынок монокорпусную версию Vortex ?
И цена у этой новой коробочки $ 166, в то время как двухкорпусной Vortex продаётся за $ 300.
Что за хитрый засцыв маркетологов?
« Ответ #21 : 09 Сентябрь, 2013, 07:54:09 am »
за 300 не пошел девайз, надо что-то делать! :D
« Ответ #22 : 09 Сентябрь, 2013, 16:40:48 pm »
Для мелколетов наверное поудобнее размещать,чем два блока,хотя и двухблочный очень небольшой,посмотрим ,может что-то покуцали внутри,хотя вроде пишут все есть  :D
« Ответ #23 : 09 Сентябрь, 2013, 16:51:36 pm »
...многие юзеры, купившие за $300 старый девайс скажут им "спасибо" за дружественный маркетинг!
« Ответ #24 : 10 Сентябрь, 2013, 14:09:17 pm »
Это врятли, Ангелос как-то очень пространно объяснял какого лешего он придумал именно двухблочник,и надо сказать убедительно  :D,в этом есть резон,маленький и легкий блок,с манюсенькими проводочками куда чувствительней ,чем массивный блок с кучей проводов от серв,например логгер в спартане не так активно реагирует на вибрации ,причем достаточно сильные,как он будет работать в маленьком моноблоке-будем посмотреть,есть у меня идея прикупить его на минититан В2 ,по крайней мере там спектрумбист не особенно хорошо помещался , и вел себя как вертолет на пару размеров крупнее-такой вальяжный,а подкрутить не удается-блок стоит прямо над передаткой хвоста и все вибрации прямиком передаются куда ненадо  :)
« Ответ #25 : 19 Сентябрь, 2013, 15:21:41 pm »
Поразмыслив, решил что мультяшно-маленькому Вортексу самое место
на мультяшно-маленьком вертолёте. И поставил его на один из МиниПротосов.
Встал отлично! Весьма соразмерно одно с другим. Заодно и прошивочку V2 облетаем...
IMAG1440 by Kulichik, on Flickr
IMAG1442 by Kulichik, on Flickr
IMAG1447 by Kulichik, on Flickr
IMAG1454 by Kulichik, on Flickr
IMAG1455 by Kulichik, on Flickr
« Ответ #26 : 19 Сентябрь, 2013, 23:05:29 pm »
 :D, дык ему в самый раз нано вортекс-не? :)
« Ответ #27 : 20 Сентябрь, 2013, 08:41:49 am »
Нановортекс не такой уж и нано  ;)
по размерам как Микроб, чуть тоньше только.
А этот, особенно датчик - то что надо
« Ответ #28 : 22 Сентябрь, 2013, 17:58:12 pm »
Сегодня с пристрастием облетал новую прошивку V2.
Ну что можно сказать? Получилось  :круто:
Но косяк с отбивкой хвоста остался: убирается, но не полностью  :-\
Настроенные пресеты типов вертолёта/головы и режимов отлично работают,
шлифовать тонкие настройки надо теперь по минимуму.
В общем, останется Вортекс жить на МиниПротосе навсегда, прижился!  :)
Оффлайн Designer
« Ответ #29 : 25 Октябрь, 2013, 17:08:39 pm »
Видео как калибровать прижав пальцем к столу меньшего брата, Vx1n
Для старшего я так понимаю процедура аналогичная.
главное точный настрой
