Технический раздел => Силовая установка => | Электро | => Тема начата: tim001 от 28 Март, 2009, 17:23:51 pm
Название: Новые Скорпиончики для 250 Тирекса и 200Gaui
Отправлено: tim001 от 28 Март, 2009, 17:23:51 pm
Во типа новинки :D
Для 250
    *  Stator Diameter ............................ 22.0 mm (0.866 in)
    * Stator Thickness ............................. 6.0 mm (0.236 in)
    * No. of Stator Arms .................................................. 9
    * No. of Magnet Poles ................................................ 6
    * Motor Wind ........................................... 24 Turn Delta
    * Motor Wire ....................... 7-Strand 0.19mm (32 AWG)
    * Motor Kv ........................................... 3900 RPM / Volt
    * No-Load Current (Io) ................... 0.83 Amps @ 6 volts
    * Motor Resistance (Rm) ............................. 0.064 Ohms
    * Max Continuous Current ............................... 14 Amps
    * Max Continuous Power ................................ 150 Watts
    * Weight ......................................... 32 Grams (1.12 oz)
    * Outside Diameter .......................... 27.9 mm (1.097 in)
    * Shaft Diameter ............................. 2.50 mm (0.098 in)
    * Body Length ................................. 22.6 mm (0.890 in)
    * Overall Shaft Length ...................... 32.6 mm (1.283 in)
[attach=#]
и для 200Gaui
    * Motor Wire ....................... 8-Strand 0.21mm (31 AWG)
    * Motor Kv ........................................... 5300 RPM / Volt
    * No-Load Current (Io) ................... 2.12 Amps @ 6 volts
    * Motor Resistance (Rm) ............................. 0.031 Ohms
    * Max Continuous Current ............................... 18 Amps
    * Max Continuous Power ................................ 130 Watts
    * Weight ......................................... 34 Grams (1.21 oz)
    * Shaft Diameter ............................. 2.30 mm (0.091 in)
[attach=#]
